Jump to content
Sign in to follow this
muresianu dorin
tv schneider stv 21o3 vt
Schneider STV2103VT este sasiu CTS-AA,deci merge cu telecomanda pilot P1696-intri in meniul de cautare cu tasta romb (install) sau cu telecomanda Philips RC8205 apesi simultan cele 2 taste romb din partea inferioara a telecomenzii -ca la Philips L6.1,Anubis AA5 etc.Pilot P4049 este echivalent IR 209 GBS ca si pilot P3051 si se foloseste la Daewoo CP330,CP375...
Share this post
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
