Jump to content
Sign in to follow this
tanase
samsung ck 20s21bt
vreau si eu o schema pt acest tv,e desincronizat pe h si v am schimbat jungla tda 8842 si tot asa face,pe av functioneaza normal
Share this post
Link to post
Share on other sites
Jungla trebuia schimbata ...ultima,dupa ce faceati o ''cura'' de electrolitici in jurul ei....
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
