valioval Posted March 7, 2014 Share Posted March 7, 2014 Va salut.Problema este la un tv Artic diagonala 51 , procesor SDA 5535-A071, jung.STV2249HOSD-urile nu se stabilizeaza , adica coboara mereu in jos ca si cum ar fugi imaginea doar OSD _urile ,dupa ce trece timpul lor de afisiere si dispar ramane o dunga neagra orizontala de 5-6 mm care coboara mereu in josIn toata perioada imaginea este buna,care ar fi va rog cauza? Quote Link to comment Share on other sites More sharing options...
tehtronics Posted March 7, 2014 Share Posted March 7, 2014 verifica circuitul din "attach" ... Quote Link to comment Share on other sites More sharing options...
xtgs Posted March 7, 2014 Share Posted March 7, 2014 incerca-ti si cu o memorie noua Quote Link to comment Share on other sites More sharing options...
Join the conversation
