nicuschiopu Posted February 28, 2014 Share Posted February 28, 2014 sasiu 11ak30s-2 totul ok. nu face st-by dau de pe telecomanda oprit si ledul ramane tot pe verde trece cam 1secunda in culoarea rosie cand pornesc din butonul de retea si se face imediat verde dar nu intra in st-by daca a mai intalnit cineva acest defect va rog cateva solutii va multumesc. Link to comment
santamihai Posted February 28, 2014 Share Posted February 28, 2014 Cititi aici .viewtopic.php?f=17&t=124195 Link to comment
nicuschiopu Posted February 28, 2014 Author Share Posted February 28, 2014 am citit in depanatorul dar nu se potriveste nimic cu defectul pe care il am eu nu am nimic ars am imagine face cautare programe sunet normal nu ia comanda pentru a trece in st-by ramane pornit numai din butonul de retea se opreste daca mai sunt ceva solutii va multumesc. Link to comment
dan cod Posted February 28, 2014 Share Posted February 28, 2014 Pai ia-o metodic dinspre procesor spre sursa si vei gasi defectul.In primul rand daca pinul procesorului trece din on in off. Link to comment
Florinel TV Posted February 28, 2014 Share Posted February 28, 2014 eu cred ca pe linga mcr22 are defect sau chiar mcr22 sa fie intrerupt sau chiar tranzistoru care face sby sa fie ars Link to comment
iuliantv Posted February 28, 2014 Share Posted February 28, 2014 schimbati optocuplor ,tl431 ,mcr22,urmariti aceata zona Link to comment
nicuschiopu Posted March 1, 2014 Author Share Posted March 1, 2014 am schimbat si mcr am masurat si tranzistorul care face st-by este bun nu stiu ce sa-i mai fac.la fel pleaca direct pe verde> Link to comment
Florinel TV Posted March 1, 2014 Share Posted March 1, 2014 pin47 procesor daca se modifica ceva la oprire si pornire din telecomanda urmareste traseu poatei fisurat cablaju sau rezistente smd intrerupte pin 47proc. pornit 0v oprit 5v succes Link to comment
nicuschiopu Posted March 1, 2014 Author Share Posted March 1, 2014 inca o anomalie am observat cand opresc tv-ul din butonul de retea ledul se face rosu nu mai inteleg ce poate fi defect in cazul de fata . Link to comment
BUGHIU Posted March 1, 2014 Share Posted March 1, 2014 inca o anomalie am observat cand opresc tv-ul din butonul de retea ledul se face rosu nu mai inteleg ce poate fi defect in cazul de fata .Q503 ...decupleaza baza sa vedeti ce se intampla?!?!Poate e defect ...procesorul....partea de st-by?!?! Link to comment
nicuschiopu Posted March 1, 2014 Author Share Posted March 1, 2014 cand pornesc direct din butonul de retea porneste direct pe verde daca dau de pe telecomanda sa faca st-by ledul ramane tot pe verde pe tub se vede filamentul aprins deci nu trece in st-by si cand intrerup de la butonul de retea ledul ramane pe rosu pana se descarca condensatorul deci se opreste de aia nu mai inteleg nimic ce sa-i mai fac. Link to comment
BUGHIU Posted March 1, 2014 Share Posted March 1, 2014 ....Cu bec pe sursa...la fel?!?! :nas:In st-by ar trebui sa ''cada'' tensiunea la 10-11v.... Link to comment
nicuschiopu Posted March 1, 2014 Author Share Posted March 1, 2014 am pus bec nu cade ramane la fel cand dau st-by din telecomanda Link to comment
BUGHIU Posted March 1, 2014 Share Posted March 1, 2014 ....se cam ingroasa gluma....Ori e defect de ''soft'' ori de ''hard''....Delimitati totusi cat de cat ...varianta!!! Incepeti cu on/off de la procesor,apoi si cu verificatul componentelor pasive de circuit (rezistentelor),nu doar cele active de pe traseul st-by. Poate e careva ''intinsa'' ohmetric...(R817,R818).... Link to comment
Florinel TV Posted March 1, 2014 Share Posted March 1, 2014 schimba optocuploru cum a spus colegu iuliantv si daca nu vezi tot pe acolo e ceva defect prin zona aia pe linga tl431 si mcr22 mai verifica d802 d812 d891 d801 r831 r833 r814 si r811 r815 si Q802 Link to comment
