GABISOR Posted February 15, 2014 Share Posted February 15, 2014 MA poate ajuta cu o schema pt.monitor12v lcd-Scott LC - 15 BL....... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 16, 2014 Share Posted February 16, 2014 Cu schema , mai greu.Asta'i cu alimentare externa 12V ?Care'i ... baiul ? Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 17, 2014 Author Share Posted February 17, 2014 arde siguranta interna,......... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 17, 2014 Share Posted February 17, 2014 Pune o foto clara cu ... maruntaiele. Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 17, 2014 Author Share Posted February 17, 2014 Placa de baza cu procesor, cu sursa de alimentare........ Quote Link to comment Share on other sites More sharing options...
moro Posted February 17, 2014 Share Posted February 17, 2014 Daca are dioda "anti-prost" este chiar paralel pe alimentare, sa nu fie scurt. Posibil ca vreunul din stabilizatoarele de tensiune sa fie defecte. Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 18, 2014 Author Share Posted February 18, 2014 arde siguranta interna dupa 1 min de la alimntare fara sa se incinga nici-o piesa sau sa fie in scurt,procesorul nu da startul......... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 18, 2014 Share Posted February 18, 2014 "arde siguranta interna dupa 1 min ...fara sa se incinga nici-o piesa sau sa fie in scurt" - de incins n'o avea timp sa se incinga , dar sa sustii ca nu'i nimic in scurt sau cu consum marit p'acolo e ... SF. Fugi cu el in service. Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 18, 2014 Author Share Posted February 18, 2014 din pacat am rezolvat cu sig.,finlul audio defect,a mai ramas cu procesorul,nu da startul,si imi trebuie o schema,(m-am satura de centre de depanare sau de depanatori buni de Gura)......... Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 18, 2014 Share Posted February 18, 2014 Ca sa dea startul , trebuiesc indeplinite niste conditii.Prima este sa fie alimentat corect.Ce scrie pe procesor ? Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 18, 2014 Author Share Posted February 18, 2014 pe eticheta alba are cod-HS2.052 SAU NS2.052 nu se vede prea bine,ten. de baza are 5v...... Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted February 18, 2014 Share Posted February 18, 2014 Ca sa dea startul , trebuiesc indeplinite niste conditii.Prima este sa fie alimentat corect.Ce scrie pe procesor ?Deja sant prea multe ...conditii...Oricum ''prima'' este ok!! Are 5v!! Quote Link to comment Share on other sites More sharing options...
moro Posted February 18, 2014 Share Posted February 18, 2014 Ce amplif audio are? Sa nu fie ceva cu comunicare digitala pe proc care sa-i semnaleze avarie si acesta din urma sa nu de-ie startul mai departe Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 20, 2014 Author Share Posted February 20, 2014 este deconectata partea audio,am curatat eticheta alba si procesorul este firmaALI,cod-M6758.A1. 0133......... Quote Link to comment Share on other sites More sharing options...
GABISOR Posted February 20, 2014 Author Share Posted February 20, 2014 este deconectata partea audio,am curatat eticheta alba si procesorul este firmaALI,cod-M6758.A1. 0133...nare nimeni o schema...... Quote Link to comment Share on other sites More sharing options...
Join the conversation
