Guest MIRCEA67 Posted February 12, 2014 Share Posted February 12, 2014 am un samsung la reparat sasiu aa41. simptomul consta: pleaca liniile pentru 3-4 sec. apoi se opreste. dupa porniri repetate televizorul pleaca. mentionez ca pe bara de 13.5v am numai 10.5 v. am inlocuit tot dioda D 807 C815. VREAU UN AJUTOR....!!!! Quote Link to comment Share on other sites More sharing options...
leoncris Posted February 12, 2014 Share Posted February 12, 2014 Sasiul este KS1A AA41-00131H ? Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted February 12, 2014 Share Posted February 12, 2014 Sasiul e scris pe cablaj intre pinii trafo linii (sau pe margine ) , daca e sursa cu integrat , schimbati electroliticul de 33uf /50v din primarul sursei !! Quote Link to comment Share on other sites More sharing options...
Join the conversation
