Jump to content
soringt
LED-uri 1W, 10W, surse, module 5050, controllere RGB
1. LED-uri 1W, surse si radiatoare
Posted Image
1leu/buc sau 45lei/50buc sau 80lei/100buc
LED 1W WARM WHITE 80-100lm 3000-3200K; 3.2-3.4V ;max.350mA
LED 1W COLD WHITE 80-100lm 6000-6500K; 3.3-3.5V ;max.350mA
Radiatoare Al pentru LED-uri de 1W sau 3W
1 LED - 0.5lei/buc
3LED-uri - 1.5lei/buc
5LED-uri - 3lei/buc
7LED-uri - 3lei/buc
Surse LED-uri 1W
- 3 x 1W - 8lei/buc
Intrare: 85-265V; Iesire: 10V; Curent:300-330mA
Dimensiuni: 22 * 16 * 16 mm
- (4-7) x 1W - 10lei/buc
Intrare: 85-265V; Iesire: 12-25V; Curent:280-330mA
Dimensiuni: 40 * 17 * 19 mm
Over voltage, overload, short circuit protection
2. LED-uri 10W - 15lei/buc sau 50lei/4buc
Posted Image
UalimL:12V I:900mA
10W WARM WHITE 3000-3200K
10W COLD WHITE 6000-6500K
10W BLUE Lungime de unda: 460-465nm
10W COLD WHITE 10.000K (18lei/buc)
10W COLD WHITE 20.000K (18lei/buc)
Cooler pentru LED10W - 7lei/buc (se vinde doar impreuna cu LED10W)
Posted Image
3. Surse LED-uri 10W
Posted Image Posted Image
Intrare: AC 85V - 265V ;Iesire 9V-12V ;curent 900mA
Temp lucru: -20°C to 80°C
Sursa 10W - 25lei/buc
Sursa waterproof IP67 pentru LED10W - 30lei
4. SET sursa + remote + LED10W RGB - 60lei/buc
Posted Image
Culoare LED :RGB
Tensiuni alim. :Red 5.4-6.6V;Green 8.7-9.3V; Blue9 9.0-9.6V.
Curent: 300-330mA
Unghi vizualizare: 140 grade
Lungimi de unda :Red 620-630nm,Green 515-525nm,Blue 455-465nm
Intensitate luminoasa:Red 100-120LM,Green 140-160LM, Blue 45-60LM
LED-ul se monteaza obligatoriu pe radiator.
5. Module LED 5050 COLD WHITE Waterproof
Posted Image
Posted Image
Modul 3LED 5050 COLD WHITE Waterproof 12V;0,72W ;90 * 15 * 5mm - 3,5lei/buc
Modul 4LED 5050 COLD WHITE Waterproof 12V; 0,96W;35 * 35 * 5mm- 4,5lei/buc
6. Module LED 5050 RGB Waterproof
Posted Image
Posted Image
Modul 3LED 5050 RGB Waterproof 12V - 5lei/buc
Modul 4LED 5050 RGB Waterproof 12V - 6lei/buc
7.Controllere RGB pentru banda de LED-uri RGB
a)Mini RF Wireless LED Remote Controller for RGB 5050/3528 LED Lights Strips - 35lei/buc
Input voltage: 5V - 24V
Output :3 Channels
Output current:<4A(each channel)
Transmission/Receiving frequency:433.92Mhz
Size:L 85 * W 40 * H 6mm
b)Controller RGB IR for RGB 5050/3528 LED Lights Strips - 15lei/buc
24 Keys IR Remote Controller for RGB LED
Connecting Mode: Common Anode
Control Range: 5-10 meters
Supply Voltage: DC 12V
Max. Load Current: 2A each color
Suporta benzi cu LED-uri 5050 RGB si 3528 RGB
Efecte implementate: Flash, Strobe, Fade, Smooth
8.1M banda RGB waterproof + Controller 44 taste - 40lei
Disponibil 1 set
Posted Image
Comanda minima 70lei
Transport+ramburs 11lei
Share this post
Link to post
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
