Jump to content
Sign in to follow this
acer1491
Tv E-BODA ULTRASLIM 21 , sasiu versiune PH
Am acest tv defect si nu am reusit sa fac rost de schema lui...am probleme in alimentare cu tz. V 512 care e spart si nu stiu tipul...tot in alimentare e ars si V 503 - ST 8812 FXAre pe sasiu procesorul TDA 11126. Pe sasiu are data fabricatiei 18-10-2010. Va rog daca are cineva disponibila schema . Va multumesc
Share this post
Link to post
Share on other sites
Procesor TDA 11126, sunet TDA 7266 sa , tz final baleiaj orizontal C5296 , tz alimentare ST8812fx , tip selector DWE-8053-V...trafo linii BSC25-F3010H...... LA BV NU POT CITIAm notat principalele componente de pe sasiu pt informare suplimentara....va multumesc
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
