mircea65 Posted December 29, 2013 Share Posted December 29, 2013 Buna ziua.La ac. tv sasiu T2S01(06)-CHINA, am rezolvat sursa-cred traznit sau supratensiune, l-am pornit insa in stanga sus imi apare simbolul KEY---. Cum se poate rezolva?MULTUMESCcu stima! Link to comment
dan-a2 Posted December 29, 2013 Share Posted December 29, 2013 Tasta PP de trei ori !! Link to comment
leoncris Posted December 29, 2013 Share Posted December 29, 2013 Intra in SETUP ( selectia se face cu butonul MENU, navigarea cu butoanele de P+/P- ) la FUNCTION selecteaza cu butonul de OK, alege LOCK cu butoanele de P+/P- si trece-l din YES in NO cu butoanele de V+/V-. La sfarsit se iese din SETUP cu butonul MENU. http://pieseelectronice.net/index.php?r ... ry&path=49 Link to comment
mircea65 Posted December 29, 2013 Author Share Posted December 29, 2013 Multumesc-nu aveam telecomanda si din panoul frontal nu mergea, am rezolvat.cu stima! Link to comment
mircea65 Posted December 30, 2013 Author Share Posted December 30, 2013 Buna dimineata.Am zis ca am terminat dar nu a fost asa-dupa ce am pus toate mufele si am strans capacul, am constatat ca nu are sonor-integrat sunet CD7523CS mono. Intrebarea mea este daca pot monta AN 7522N stereo, fara sa conectez pinii 10, 11, 12, din schemele celor doua CI pinii mentionati sunt pt. canalul 2. Tens. de 12v pe pin 1 este prezenta.multumesc.cu stima! Link to comment
leoncris Posted December 30, 2013 Share Posted December 30, 2013 Sigur ai conectat corect ... mufele ? Link to comment
mircea65 Posted December 30, 2013 Author Share Posted December 30, 2013 Sigur da, doar 2mufe am avut de pus, si doar una cu 2pini langa integratul de sunet-nu prea fac greseli de genul asta.cu stima! Link to comment
catalin004 Posted December 30, 2013 Share Posted December 30, 2013 lipeste mufa aia cu 2 pini ca s-ar putea sa fi impins in ea pana a exfoliat cablajul Link to comment
mircea65 Posted December 30, 2013 Author Share Posted December 30, 2013 Nu este de acolo, am verificat innainte sa postez!cu stima! Link to comment
dan-a2 Posted December 30, 2013 Share Posted December 30, 2013 Da, merge inlocuit pin la pin , fara cele 3 terminale !! Link to comment
mircea65 Posted December 30, 2013 Author Share Posted December 30, 2013 Multumesc-o sa fac inlocuirea dupa-amiaza si va spun rezultatul.cu stima! Link to comment
mircea65 Posted December 30, 2013 Author Share Posted December 30, 2013 Am rezolvat-functioneaza fara probleme.multumesc tuturor.cu stima! Link to comment
