catalin004 Posted December 28, 2013 Share Posted December 28, 2013 Tensiuni normale pe sursa.....la pornire incep scapari de fit de la firul de inalta catre bobina de deflexie sau pe tub...am verificat lipituri reci dar nu mai stiu ce sa-i fac Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted December 28, 2013 Share Posted December 28, 2013 Cablu FIT nu este fisurat/crapat?!? Umezeala pe tub/sasiu/?!?!? Merge tv-ul cu aceste scapari sau doar ''scaparile'' apar si rastru/imagine....nu?!?!?!?! Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 este firul fisurat....se vedea la intuneric...ce-i pot face?stima Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted December 28, 2013 Share Posted December 28, 2013 .....schimbat cu altul de la un trafo defect!!!!! Lipit bine si izolat .....la fel ,chiar foarte bine izolat ,in zona lipiturii!!!! Il taiati cat mai aproape de trafo ca sa-l schimbati ....tot. Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 deci sa-l tai cat mai aproape de trafo linii....cu ce-l izolez?nu pot sa-l izolez doar in acel punct?are un mic punct negru Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted December 28, 2013 Share Posted December 28, 2013 Curatati bine acolo , faceti rost de o bucata de canalete (parca asa ii zice ) de vreo 10cm , puneti firul in el , si umpleti cu silicon !! >> eu am ceva pistol cu rezistenta si bare de silicon !! Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted December 28, 2013 Share Posted December 28, 2013 ....sau o seringa de plastic....taiata la capete....introdusa pe fir inainte de lipire ....lipit firul nou.....tras seringa peste partea lipita....turnat silicon din belsug in seringa si.....gata treaba!!! :daP.S -Canaletele....nu stiu ce sant,mea culpa Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 am lipit si am tras un manson de la o ciuperca de fit, de fapt de la firul defect....apoi am imbibat-o in plastic....se pare ca nu fasaie si nu se aude nimic...merge super....stima si Sarbatori Fericite tovarase BUGHIU....La multi ani!!!am avut niste banda izolayoare pentru tensiuni inalte (de la cez)...dar din pacate nu o mai gasesc...... :cry: Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted December 28, 2013 Share Posted December 28, 2013 ''Tovaraş'' ?!?!?!?! off, dar nu-mi divulga public ....identitatea Quote Link to comment Share on other sites More sharing options...
leoncris Posted December 28, 2013 Share Posted December 28, 2013 Eu folosesc un Scotch , rezistent la 35Kv , iar peste un tub termocontractabil.Banda kapton izolata adeziva 35KV, 9mmX33m Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 Eu aveam acea banda de 44kv.....dar nu o mai gasesc,,,,si sunt in concediu ca sa iau alta.....dar vad ca merge bine si treaba asta....destul de bine.....testata cu mana ))stima si mii de multumirileoncris de unde iei scotch poate nu mai au la fabrica ....? Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 ''Tovaraş'' ?!?!?!?! off, dar nu-mi divulga public ....identitatea ma refeream la colegeabilitatea de pe forum Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted December 28, 2013 Share Posted December 28, 2013 Eu folosesc un Scotch , rezistent la 35Kv , iar peste un tub termocontractabil.Iar te-ai ....aflat in ....discutie.... vad ca nu ma .....asculti ... Quote Link to comment Share on other sites More sharing options...
catalin004 Posted December 28, 2013 Author Share Posted December 28, 2013 heiiiii....nu va certati......este Craciunul!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
