dragutzzz_112 Posted December 18, 2013 Share Posted December 18, 2013 am imaginea intr-un colt verde si intr-un colt mov. Iam schimbat PTC-ul iam schimbat si bobina de demacnetizare si tot la fel. Am dat si cu macnetul prin fata tubului si tot la fel... Ma puteti ajuta si pe mine in aceasta problema? Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted December 18, 2013 Share Posted December 18, 2013 Se aude la pornirea la rece zgomotul specific demagnetizarii >> mai incearca si cu alt PTC. , daca nu merge posibil ca tv . sa fi luat o cazatura ,ceva si s0a descentrat masca t.k. !! Quote Link to comment Share on other sites More sharing options...
dragutzzz_112 Posted December 18, 2013 Author Share Posted December 18, 2013 la pornirea zgomotul specific demagnetizarii nu se aude. Am incercat si cu alt ptc. Am pus bec in locu la bobina 220v 60w si se aprinde becu Quote Link to comment Share on other sites More sharing options...
dan cod Posted December 18, 2013 Share Posted December 18, 2013 Curios.Poate e lovit sau foarte magnetizat si atunci ar trebui bobina externa. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2013 Share Posted December 18, 2013 In serie cu bobina de demagnetizare aveti un termistor, verificati continuuitatea acestuia. Quote Link to comment Share on other sites More sharing options...
dragutzzz_112 Posted December 18, 2013 Author Share Posted December 18, 2013 am masurato imi da 14 ohm Quote Link to comment Share on other sites More sharing options...
raileanu florin Posted December 18, 2013 Share Posted December 18, 2013 de acst defect mam ocupat si eu acuma si lam rezolvat mia loat teapa de citeva ori cu ptc urile ereau defecte din fabrica si am loat unul din dezmembrari si functioneaza perfect Quote Link to comment Share on other sites More sharing options...
raileanu florin Posted December 18, 2013 Share Posted December 18, 2013 tresa de pe tub trebuie ceva de gen 11 sau 13 O si ptc sa aiba 9 O daca e de aceasta valoare la tine Quote Link to comment Share on other sites More sharing options...
Join the conversation
