Guest titel71 Posted December 12, 2013 Share Posted December 12, 2013 am un tv teletech model ctv1406 , nu pot schimba banda de sunet,acum este pe DK si intru in meniu sa schimb in BG si nu schimba, care este cauza? Quote Link to comment Share on other sites More sharing options...
dan cod Posted December 12, 2013 Share Posted December 12, 2013 Probabil nu o are activa trebuie intrat in service si activata.Este AK30 sau 36? Quote Link to comment Share on other sites More sharing options...
Guest titel71 Posted December 12, 2013 Share Posted December 12, 2013 Este ak36,cum sa o activez? Quote Link to comment Share on other sites More sharing options...
leoncris Posted December 12, 2013 Share Posted December 12, 2013 La OP2 , BIT3 , trebuie trecut in ... 1. Quote Link to comment Share on other sites More sharing options...
dan cod Posted December 12, 2013 Share Posted December 12, 2013 TRebuyie intrat in service cu meniu 4725 si pa OP2 bitul 3 si 4 sa fie 1 Quote Link to comment Share on other sites More sharing options...
Guest titel71 Posted December 12, 2013 Share Posted December 12, 2013 Va rog mai multe detalii ?! Quote Link to comment Share on other sites More sharing options...
dan cod Posted December 12, 2013 Share Posted December 12, 2013 Nu ai inteles.Tastezi meniu 4 7 2 5 asa se intra in service apoi la optiunea OP2 ai bitii si trebuie ca 3 si 4 sa fie 1 ca sa ai BG/DK.Daca nu te pricepi il vei strica mai rau. Quote Link to comment Share on other sites More sharing options...
leoncris Posted December 12, 2013 Share Posted December 12, 2013 BIT3 este deja 1 , schimbi doar BIT4 din 0 in 1. Quote Link to comment Share on other sites More sharing options...
Guest titel71 Posted January 4, 2014 Share Posted January 4, 2014 Buna ziua! si La multi ani!! ,,,Dupa ce au trecut sarbatorile am incercat dinou sa rezolv problema cu sunetul si am intrat in ,,service meniu ,, am facut intocmai cum ma-ti sfatuit si acum am sunet pe ambele benzi, va multumesc pt sfaturi Quote Link to comment Share on other sites More sharing options...
Join the conversation
