Jump to content
casiu
Samsung CW28C7VH sasiu S53A - child look
Tv-ul este blocat. La pornire apare child look pt 22 secunde dupa care trece in stby. Exista o procedura de deblocare sau are cineva un dump care sa rezolve problema? Ms anticipat!
a-ti incercat pornirea din telecomanda? poate are blocat doar panaul frontal,sau pute-ti incerca dumpul asta http://wsady.elektroda.pl/download251.html
Link to comment
Share on other sites
intra in meni servicee cu una din aceste variante Method 1 Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Method 2 Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence. Method 3 With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote. Method 4 With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote. Method 5 With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote. Method 6 With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Link to comment
Press Menu,press the up-down button to select set-up,press Enter button,press the up-down button to select v-chip,then press the enter button,press the number of buttons to enter your 4-digit pin,the v-chip menu is displayed, press the up-down button to select Parental Guidelines,then press the enter button, press the up-down button to what you want to do, press the exit button to exit.Good luck !
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
