electrod90 Posted November 25, 2013 Share Posted November 25, 2013 Salut ... a ratacit pe la mine o plasma tv LG 42PC1R ... aparent televizorul functiona insa am constatat ca dupa 2, 4, 6 ore tv-ul se stinge ,ramane in stand by si incerca continu sa pornesca ... cupleaza releele din sursa ,decupleaza si tot asa la diferite intervale de timp 2sec 10sec... din cand in cand porneste si functioneaza corect.Vreau sa precizez ca dupa nenumaratele incercari de pornire cu durata scurta de functionare care poate sa fie de la 10 15sec am observat ca atunci cand schimb canalul tv-ul cade in stand by si incerca continu sa apornesca ... dar nu este o regula uneori se poate schimba si canalul.Am verificat cu Capacimetrul fiecare condensator in parte din sursa si am inlocuit 3 cond de 1000uF care erau devalorizati 700uF in rest totul pare ok .. sper sa intelegeti descrierea, ce ma sfatuiti ? multumesc Link to comment
leoncris Posted November 25, 2013 Share Posted November 25, 2013 " LG 42PC1R ..." - cu ce terminatie ?Nu se ambaleaza termic nimic p'acolo ? Link to comment
electrod90 Posted November 25, 2013 Author Share Posted November 25, 2013 terminatia ZH ... nimic termic ... Link to comment
leoncris Posted November 25, 2013 Share Posted November 25, 2013 Sasiu PP62A http://elektrotanya.com/lg_pp62a_chassi ... nload.html Link to comment
electrod90 Posted November 26, 2013 Author Share Posted November 26, 2013 nu a intalnit nimeni acest defect ? Link to comment
ovidiuiosif Posted November 27, 2013 Share Posted November 27, 2013 Salut, Daca monteaza acest alimentator trebuie neaparat inlocuit cu cel de-al doilea, asa recomanda LG! Link to comment
electrod90 Posted December 1, 2013 Author Share Posted December 1, 2013 Salut, Daca monteaza acest alimentator trebuie neaparat inlocuit cu cel de-al doilea, asa recomanda LG!nu exista nici o rezolvare la aceasta problema ? Link to comment
ovidiuiosif Posted December 2, 2013 Share Posted December 2, 2013 Salut, Daca monteaza acest alimentator trebuie neaparat inlocuit cu cel de-al doilea, asa recomanda LG!nu exista nici o rezolvare la aceasta problema ?Daca LG recomanda una ca asta, mai e loc de alternativa!? Link to comment
electrod90 Posted December 9, 2013 Author Share Posted December 9, 2013 am observat ca un chopper face un zgomot destul de puternic atat la pornire cat si in timpul functionarii ? Link to comment
iuliantv Posted December 9, 2013 Share Posted December 9, 2013 am observat ca un chopper face un zgomot destul de puternic atat la pornire cat si in timpul functionarii ? Link to comment
iuliantv Posted December 9, 2013 Share Posted December 9, 2013 am observat ca un chopper face un zgomot destul de puternic atat la pornire cat si in timpul functionarii ?la mine dupa ce a-m inlocuit ceva condesatori prin sursa,aceeasi problema,a m luat toata sursa la relipit,si tv ul a mers cca 3 luni,pana a venit vara si a dat de caldura a revint si defectul,l am luat la rost dar fara rezultat,dupa care mi-a trecut prin cap sa pun de test un cooler care sa bata pe procesor,si surpriza tv ul mergea,a m pozitionat coolerul de cca 3x3cm 12v pe zona procesor,a luat curent de pe o bara de 6v parca ,si pe plus a-m montat o rezistenta de 2 ohmi 0,25w plus un condesator 25v 220mf minusul la masa plusul dupa dioda si rezistenta,si tv ul merge de asta vara.daca nu v a place metoda mea,pute-ti macar face un test cu un cooler pe zona procesor,success Link to comment
