iuliantv Posted November 22, 2013 Share Posted November 22, 2013 rog ajutorul,la cca 20km de mine se afla acest tv sunny at142t1nf (posibil procesor tda11126....cam asta a-m gasit pe net)care are nevoie de telecomanda,e cam greu pentru propietar sa-l aduca,i-am trimis vre-o 5 telecomenzi nici una nu lucreaza,np51 ,sunny schnaider,kw-55l7,tb001,...,urmeaza sa-i dau un n18,nipon cu calendar sa vad daca gasesc un tc39,vek06,asr100 IIIG,dar mi-ar fi de ajutor ,daca a intalnit cineva acest tv ,si a-r sti cineva exact ce telecomanda merge,va multumesc Quote Link to comment Share on other sites More sharing options...
dan cod Posted November 22, 2013 Share Posted November 22, 2013 Eu as incerca 1523 MFY.Nu sunt 100% dar parca asa tin minte. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted January 11, 2014 Author Share Posted January 11, 2014 Eu as incerca 1523 MFY.Nu sunt 100% dar parca asa tin minte. a-m gasit si un cod MFY1556 98% ,ceva functii incurcate dar in rest e ok,mai merge si cu cod de toshiba mfy 19,a ajuns tv-ul la mine si a-m aflat m-ai multe,procesor tda11126ps/n3/3,se gaseste si telecomanda dar momentan nu o au la bacau,http://telecomenzi.pentagon2000.ro/index.php?route=product/product&filter_name=ir1556&filter_description=true&product_id=974 Quote Link to comment Share on other sites More sharing options...
Join the conversation
