cnc Posted November 17, 2013 Share Posted November 17, 2013 acest tv model n2080mtg prezinta urmatorul simtom la prima pornire porneste fara probleme dupa 30 de m inute daca este oprit si pornit imediat porneste fara imagine daca este lasat 1-2 minute porneste fara probleme Quote Link to comment Share on other sites More sharing options...
leoncris Posted November 17, 2013 Share Posted November 17, 2013 Asta nu'i sasiu PT90A ?O cura de C_uri e binevenita + verificare lipituri ... reci. Quote Link to comment Share on other sites More sharing options...
doru tv Posted November 17, 2013 Share Posted November 17, 2013 cateva detalii,procesor,jungla,cadre,sursa!a-ti facut ceva masuratori pe sursa? Quote Link to comment Share on other sites More sharing options...
cnc Posted November 17, 2013 Author Share Posted November 17, 2013 am schimbat jungla stv 2248 deo cam data vad ca merge ,sa vad daca mai apare defectul Quote Link to comment Share on other sites More sharing options...
Join the conversation
