leo 17 Posted November 14, 2013 Share Posted November 14, 2013 am un tv modelul sus mentionat cu defectul ca nu pleaca tensiunea de inalta pe transformatorul de linii ,tranzistor final linii bun ,fara scurt pe iesiri ,verificat diode ,condesatori filtraj tensiuni iesire pe traf...sursa e ok ,probat pe bec ,am incercat sa l pornesc fara cadre si tot nu o ia ...pus becul in colector tranzistor final linii se aprinde ...sa fie transformatorul cu spire in primar in scurt ?pe transformatorul de linii nu se mai poate citi nimic ,ma puteti ajuta cu ceva echivalente de trefuri ..va multumesc Link to comment
laur_12 Posted November 14, 2013 Share Posted November 14, 2013 verificati bobina de deflexie scoatetio afara se poate verifica vizibil (arsura) Link to comment
Nostalgic Posted November 14, 2013 Share Posted November 14, 2013 dar vin impulsuri in baza finalului linii.Verifica cu un osciloscop.Daca.... ai. Link to comment
Marian C Posted November 14, 2013 Share Posted November 14, 2013 viewtopic.php?f=16&t=36533&hilit=p2040mts http://www.hrdiemen.com/search/index?ut ... p+2040+mts Link to comment
leo 17 Posted November 14, 2013 Author Share Posted November 14, 2013 bobina de deflexie e ok ,masurata Link to comment
Marian C Posted November 14, 2013 Share Posted November 14, 2013 cv10 e bun ? filtrajul pe 8v alimentare jungla Link to comment
leo 17 Posted November 14, 2013 Author Share Posted November 14, 2013 cv 10 e bun ????? Link to comment
dan cod Posted November 15, 2013 Share Posted November 15, 2013 Da finalul linii jos si pune osciloscopul in baza driver.Sa vezi daca ai impulsuri acolo. Link to comment
leo 17 Posted November 15, 2013 Author Share Posted November 15, 2013 problema e ca nu am osciloscop ...totusi o sa fac comanda de un transformator de linii Link to comment
leo 17 Posted November 23, 2013 Author Share Posted November 23, 2013 am pus transformatorul de linii nou ,am gasit soclul defect dupa ce l am schimbat tv functioneaza doar ca am cursa inversa ,tensiune vudeo 200 v ,pe catozi am 190 de v ,din matrice pleaca o tensiune egala pe fiecare culoare ,tranzistori pe finali ok ,g2 se regleaza ...nu stiu ce ar putea fii ..un sfat daca se poate Link to comment
dan cod Posted November 23, 2013 Share Posted November 23, 2013 Imagine ai ceva sau deloc doar cursa inversa?sonor ai? Link to comment
leo 17 Posted November 23, 2013 Author Share Posted November 23, 2013 fara inagine doar cursa inversa Link to comment
leo 17 Posted November 23, 2013 Author Share Posted November 23, 2013 sunet am .......... Link to comment
dan cod Posted November 23, 2013 Share Posted November 23, 2013 Interesant cu catozii la 190V ai ecran alb cu linii de intoarcere.Nu-i cumva prea mare screenul? Link to comment
leo 17 Posted November 23, 2013 Author Share Posted November 23, 2013 reglez g1 pana la jumatate ecran negru ,dacamaresc tensiunea imi apare cursa inversa ,in ambele situatii pe catozi am 190 de v Link to comment
