Guest adrian_tepurlui Posted November 14, 2013 Share Posted November 14, 2013 Salut! M-am pricopsit cu un tv Thomson 37LB130S5, fara sursa de alimentare... Daca are cineva vreo schema, fotografie sau tensiuni ale acestei surse, i-as fi recunoscator! Sau daca are cineva asa ceva, doresc sa cumpar... Quote Link to comment Share on other sites More sharing options...
leoncris Posted November 14, 2013 Share Posted November 14, 2013 Sasiu ... IFC 130 . http://www.electronica-pt.com/index.php ... /id,14789/ http://www.eserviceinfo.com/downloadsm/ ... 052B5.html Quote Link to comment Share on other sites More sharing options...
Join the conversation
