ignaemil Posted November 12, 2013 Share Posted November 12, 2013 domnilor va saluta emil va rog daca este posibil o schema electronica a tv kokusai model 54tcb065tx' si ceva echivalente pentru tz but11 afi [se poate masura cu un aparat de masura obisnuit]va multumesc anticipat cu stima emil Link to comment
dan cod Posted November 12, 2013 Share Posted November 12, 2013 este tv thomas ala.BUT11 se poate masura Link to comment
leoncris Posted November 12, 2013 Share Posted November 12, 2013 http://www.eserviceinfo.com/downloadsm/ ... homas.html http://www.eserviceinfo.com/downloadsm/ ... homas.html Link to comment
ignaemil Posted November 13, 2013 Author Share Posted November 13, 2013 domle leoncris nu pot sa accesez[sau nu stiu] schema ce ati trimiso va rog frumos mai explicit si ceva echivalenti pentru tz but11 care pot sa le recuperez din tv cu stima emil Link to comment
dan cod Posted November 13, 2013 Share Posted November 13, 2013 In loc de BUT11 merge si BUT12 eventual BU508 dar asta e mai mare.Eu am folosit si BD243C(neaparat cu C ca altfel este tensiunea prea mica) Link to comment
ignaemil Posted November 13, 2013 Author Share Posted November 13, 2013 multam fain domnul dan cod am si bu 508 si bd243cu c inca ceva te rog domnul dan o schema pentru tv thomas ca nu inteleg ce mia trimis domnul leoncris cu respect emil. Link to comment
dan cod Posted November 13, 2013 Share Posted November 13, 2013 Numai maine cand voi fi la atelier pot trimite schema. Link to comment
dan-a2 Posted November 13, 2013 Share Posted November 13, 2013 Presupun ca tz . BUT face parte din comutatorul electronic din standby , pana sa montezi altul ,rezolva intai sursa > schimba cei doi electrolitici din primar ( parca 10uf si 47uf ) > cupleaza becul in locul finalului linii ,si vezi ca tensiunile debitate sa fie o.k. Schema o gasesti pe net !! >> succes !! Link to comment
bobo Posted November 13, 2013 Share Posted November 13, 2013 inainte de a inlocui comutatorul electronic format din but11af si 2sa1013 inlocuiti obligatoriu condul de 47 micro din sursa ca altfel o sa inlocuiti iar acesti tranzistori.procedati exact cum a zis colegul dan-a2. THOMAS TCB061X TV D.pdf Link to comment
ignaemil Posted November 13, 2013 Author Share Posted November 13, 2013 multumesc frumos domnilor dan cod si dan a2 .se vede de la o posta ca vreti sa dati o mina de ajutor si sa intelegeti un pensionar care sa descurcat cu tv pe tuburi electronice si cu tz acuma este un pic mai greu si fara documentatie noroc cu dumneavoastra ca suteti oameni seriosi cu stima si respect emil Link to comment
ignaemil Posted November 19, 2013 Author Share Posted November 19, 2013 da domnule dan-a2 am schimbat electrolitici am scos tz final linii pe q504 care este un d 1710 am pus pe colector baza un bec si as vrea sa stiu care sint tensiunile dupa cheoper.cu stima emil Link to comment
dan cod Posted November 21, 2013 Share Posted November 21, 2013 U1 cam 110-115v trebuie sa fie. Link to comment
ignaemil Posted November 22, 2013 Author Share Posted November 22, 2013 domnilor vasi mai ruga ceva idei cu tv thomas am scos tz am pus un bec intre colector emitor si nici un rezultat becul nu se stinge nici nu slabeste pe c605 am 350vcu stima emil.dupa cheoper nu am nici o tensiune. Link to comment
Nykky1976 Posted November 22, 2013 Share Posted November 22, 2013 pai domnule draga nu intre C-E la tranzistorul D1710 ca acela este final sursa si acolo este normal 300Vcc dumneavoastra schimbati c-uri din primar 10 si 47 mf si montati becul in secundar dupa redresare si inainte de comutatorul cu BUT11 acolo trebuie sa aveti tensiune in STBY pina la maxim 125V nu mai mult Link to comment
