eugenchis Posted November 12, 2013 Share Posted November 12, 2013 respecte la acest tv lg sasiu MC 64A s-au inlocuit trafo linii , toti cond. din primarul sursei si c408, si tv-ul porneste foarte greu din stby dupa circa 30-50 incercari , U1 in stby 130v dupa pornire 111.8v, trafo linii montat este FBT 8163 , as dori un sfat. multumesc mult. Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted November 12, 2013 Share Posted November 12, 2013 Este echivalentul direct al transformatorului original? Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 12, 2013 Author Share Posted November 12, 2013 nu stiu, pe trafo vechi este scris TD 08JD 05D si mai are si P 802HC 25, de la un magazin de piese electr. mi -sa recomandat acest( trafo FBT 8163). Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted November 12, 2013 Share Posted November 12, 2013 Intr-adevar este unul din cele 6 tipuri de HR care merg la acest sasiu. Dati va rog si tipul de tv exact. Pe bec sursa porneste normal? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted November 12, 2013 Share Posted November 12, 2013 c 824 s-a schimbat?c830.840? Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 12, 2013 Author Share Posted November 12, 2013 tv lg model CF 20D 70X diagonala 51, s-au inlocuit si c824 si la incercare sursa pe bec aceeasi problema pe IC 840 qut 5v. care sa fie trafo cel bun oare? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted November 12, 2013 Share Posted November 12, 2013 trafo linii de ce l-ai schimbat? Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 12, 2013 Author Share Posted November 12, 2013 tv-ul pleca din stby dar se supraincalzea final linii si lipsa rastru, ( trafo linii era f cald), motivul inlocuirii. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted November 12, 2013 Share Posted November 12, 2013 normal hr8163=7666=7485=7906,toate pe lg/goldstarpersonal n-am gasit pina acum niciunul defect de nou sa nu porneasca,cele chinezesti se strapung dupa 3-4 anicred ca tot un c face belele,daca porneste merge ok? Quote Link to comment Share on other sites More sharing options...
iuliantv Posted November 12, 2013 Share Posted November 12, 2013 normal hr8163=7666=7485=7906,toate pe lg/goldstarpersonal n-am gasit pina acum niciunul defect de nou sa nu porneasca,cele chinezesti se strapung dupa 3-4 anicred ca tot un c face belele,daca porneste merge ok?nu a-s baga mana in foc pentru un trafo chinezesc ,nici pentru o functionare de cateva ore,a pus pe un orion un trafo chinezesc ,in cateva zile a iesit zeama din el,acelasi magazin alt traf identic cred ca mere si acum dupa ceva luni,nu spun ca nu folosesc si nu cumpar asa ceva dar nu pot baga mana in foc pentru ele,deci parerea mea nu pune ti baza pe ele,oricum nu cred ca acolo e buba colegului nostru,un prieten avea un lg ce pornea dupa un sfert de ora,si odata ce pornea asculta comenzi dupa alt sfert de ora,daca dadeai ch+(spre ex din tv sau tel) dadeai juma de bere pe gat si daca aveai noroc schimba si canalul,orice functie dadeai la sfert de ora o facea,mi a donat mie placa,si dupa ceva chin a m abandonat o,la ceva luni mi a cazut un tv identic,l am reparat si de curiozitate a m pus procesorul meu,sa vezi si sa nu crezi el era buba,deci v a recomand ,cum reusi-ti sa porni ti tv ul sa vede ti daca nu cumva si functiile sant cu intarziere,oricum verifica-ti laga trafo driver si tranzistor driver este un condesator fix l-am m ai gasit aproape spre scurt,si alta buba e ,si am intalnit-o este unul din condesatorii inseriati cu quarturile jungla Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 13, 2013 Author Share Posted November 13, 2013 deci sa inteleg ca trafo linii nou montat FBT 8163 la diagonala de 20" este normal , as dori sa-mi confirmati si valoarea nomala la U1 care ar trebui sa fie? multumesc. Quote Link to comment Share on other sites More sharing options...
iuliantv Posted November 13, 2013 Share Posted November 13, 2013 deci sa inteleg ca trafo linii nou montat FBT 8163 la diagonala de 20" este normal , as dori sa-mi confirmati si valoarea nomala la U1 care ar trebui sa fie? multumesc.eu personal zic ca este ok u1, daca a ti schimbat conzi din sursa nu ave ti dece sa v a face-ti griji,nu a m intalnit probleme cu aceste surse Quote Link to comment Share on other sites More sharing options...
palcu ion Posted November 15, 2013 Share Posted November 15, 2013 cred ca tot un c face belele,daca porneste merge ok?s-a rezolvat defectul ? Quote Link to comment Share on other sites More sharing options...
eugenchis Posted November 15, 2013 Author Share Posted November 15, 2013 s-a rezolvat, cind am dezlipit trafo linii defect s-a fortat putin rezultind contacte imperfecte , refacut lipituri in zona final linii si functionare normala ,multumesc de ajutor . Quote Link to comment Share on other sites More sharing options...
Join the conversation
