cristybadea Posted November 11, 2013 Share Posted November 11, 2013 Am primit acest tv care se manifesta astfel.Se aprinde ledul de st-bye dar nu porneste la comanda on.Tensiunile in secundarul sursei sunt 118v,14v si 40v.Rog ajutorul dvs in depistarea defectului.multumesc Link to comment
leoncris Posted November 11, 2013 Share Posted November 11, 2013 Sasiu S5E. http://elektrotanya.com/toshiba_218d7s. ... nload.html Vezi ca ai tensiunile marite acolo. 112V +B , 12V si -30V , tensiuni corecte, asa ca vezi ce'i prin primar , opto ... Link to comment
dan cod Posted November 11, 2013 Share Posted November 11, 2013 Ce procesor are?Procesorul da comanda de on? Link to comment
cristybadea Posted November 11, 2013 Author Share Posted November 11, 2013 Procesor M50436-589SP are pe pinul 6(power)1,34v care nu se schimba la comanda on respectiv off.Fata de schema primita,la mine in placa Q831 este un tranzistor PNP iar pe schema este dat ca fiind NPN. Link to comment
dan cod Posted November 11, 2013 Share Posted November 11, 2013 Telecomanda ai una sigur buna pentru el? Link to comment
leoncris Posted November 11, 2013 Share Posted November 11, 2013 Nu are ce cauta pnp acolo , vezi poate te uiti la Q834. Link to comment
cristybadea Posted November 11, 2013 Author Share Posted November 11, 2013 Revin cu cateva noutati.Dupa refacerea unor lipituri ce mi s-au parut imperfecte tv-ul a pornit dar inainte de a se lumina tubul a intrat in protectie.Dupa cateva verificari am gasit finalul linii in scurt.Nu-mi pot da seama de la ce.Tensiuneile acum cu finalul linii scos sunt 118v,-31v si15,5v iar tensiunea pe trafo driver este de 80v.Asta asa trebuie sa fie?multumesc Link to comment
cristybadea Posted November 11, 2013 Author Share Posted November 11, 2013 Nu are ce cauta pnp acolo , vezi poate te uiti la Q834.De Q831 vb care este cel original pe sasiu si este A1321 Link to comment
cristybadea Posted November 11, 2013 Author Share Posted November 11, 2013 Am pus ca final un S2000(nu dispun de D1427 momentan) si am schimbat C440 si C444 si tv-ul functioneaza normal.O sa reziste finalul linii oare? Link to comment
cristybadea Posted November 16, 2013 Author Share Posted November 16, 2013 Am pus ca final un S2000(nu dispun de D1427 momentan) si am schimbat C440 si C444 si tv-ul functioneaza normal.O sa reziste finalul linii oare?Functiona normal fara semnal video.La introducerea de semnal tv-ul are o tiuiala in zona traff-ului de linii si imaginea este si ea de nedescris de proasta.Am schimbat finalul linii cu un Bu 508DF dar fara nicio schimbare.va rog putin ajutor Link to comment
cristybadea Posted November 21, 2013 Author Share Posted November 21, 2013 Tv rezolvat cu succes.Vinovat de toate anomaliile a fost C408 (10mf/63v).Multumesc tuturor celor care mi-uu dat idei si ajutor.Multumesc Link to comment
