Guest atutu Posted October 27, 2013 Share Posted October 27, 2013 Buna ziua!Va rog ajutor,am o plasma Samsung PS-42C62HX/XEH Typ:LI42C6 cu versiunea SW T-LIL2PEUMD-1004.0 la care am sters dintr o eroare prosteasca date din memoria Flash 25L1605AM2I.Nu gasesc nicaieri un firmware LILY2 42R V.1004.0?Nu pot sa cred ca dintre toti specialistii din tara asta nu sa ,,lovit''macar unul singur de acest tip de soft.Detin interfata + cablu serial rs232c si programele aferente:ISP,FLASH DOWNLOADER,MTKVa multumesc pentru atentia acordata! Link to comment
popa ionut Posted October 27, 2013 Share Posted October 27, 2013 spune codul de placa ori postaza o poza cu placa de baza Link to comment
Guest atutu Posted October 27, 2013 Share Posted October 27, 2013 spune codul de placa ori postaza o poza cu placa de bazaPlaca de baza:BN41-00936C si are lipita o eticheta cu versiunea LILY II 42R V.1004.0(versiunea de software,cred) Link to comment
Guest atutu Posted October 27, 2013 Share Posted October 27, 2013 Specific faptul ca dupa stergerea datelor din flash rom tv nu mai porneste din st.by Link to comment
popa ionut Posted October 27, 2013 Share Posted October 27, 2013 Da,stiu o sa ma uit maine la service sa vad daca am vre-o placa cu versiunea care iti trebuie. Link to comment
Guest atutu Posted October 27, 2013 Share Posted October 27, 2013 Multumesc pentru intentie,nu prea am solutii,numai un backup de pe alta placa ma salveaza Link to comment
popa ionut Posted October 28, 2013 Share Posted October 28, 2013 Dupa cum v-am promis aveti in atasament fiserul bin,parola in m.p Link to comment
Guest atutu Posted October 28, 2013 Share Posted October 28, 2013 Va multumesc mult,maine ii fac un upgrade si va anunt rezultatul.O seara buna! Link to comment
popa ionut Posted October 30, 2013 Share Posted October 30, 2013 Ati reusit?daca vreti ceva mai nou am si o alta versiune de soft noua,dar aceea trimisa este din fabrica. Link to comment
Guest atutu Posted November 1, 2013 Share Posted November 1, 2013 Din pacate nu am reusit sa ma conectez cu interfata cu 74ls244 incerc sa fac una cu 74hc244 si sa folosesc softul SPYFLASH 1.4 si va tin la curent.Poate gasiti si un continut pentru dumpul 24c256 de pe acest sasiu si in acest caz programez 2 memorii noi.Am 2 sapt de cand stau cu tv-ul asta si am ajuns la limita rabdarii.Prostia mea a fost ca am incercat sa programez spy cu IC PROG care la optiunea 25160 vede numai 256KB Link to comment
popa ionut Posted November 1, 2013 Share Posted November 1, 2013 Daca nu reusiti trimiteti flash-ul si eepromul 24c256 la mine si ce vreti sa mai scrieti si le programez eu,achitati drumul dus-intors. FanCurier Link to comment
Guest atutu Posted November 1, 2013 Share Posted November 1, 2013 Am reusit sa programez 25l1605 flash dar rezultatul acelasi:TV ST-BY...nu pot sa cred asa ceva!Va rog poate imi trimiteti si un dump pentru 24c256 la care am facut un reset cu sc.circ. pini 5,6 dar degeaba.Va raman profund indatorat,poate ma voi revansa intr-un fel.Astept un dump pentru 24c256,e ultima solutie Link to comment
popa ionut Posted November 1, 2013 Share Posted November 1, 2013 Cred ca ati stricat altceva pe acolo,numai luni cand ajung la service o sa va pot trimite si dump-ul pentru 24c256,dar nu se strica nimic in soft daca ati facut scurt pe SDA-SCL sigur ati scris corect bin-ul in flash?ati verificat ce ati scris?ati citit binu si ati comparat cu cel original? Link to comment
popa ionut Posted November 5, 2013 Share Posted November 5, 2013 Am reusit sa programez 25l1605 flash dar rezultatul acelasi:TV ST-BY...nu pot sa cred asa ceva!Va rog poate imi trimiteti si un dump pentru 24c256 la care am facut un reset cu sc.circ. pini 5,6 dar degeaba.Va raman profund indatorat,poate ma voi revansa intr-un fel.Astept un dump pentru 24c256,e ultima solutieAici aveti binu http://www1.zippyshare.com/v/64762497/file.html Link to comment
popa ionut Posted November 28, 2013 Share Posted November 28, 2013 Pana la urma s-a rezolvat problema? Link to comment
