Dr4g0n Posted July 26, 2013 Share Posted July 26, 2013 Am nevoie de ajutor cu monitorul asta porneste si se opreste dupa o secunda , partea de sus a ecranului nu e luminata Am desfacut , avea condensatorul de 220uf/25v inflorit (intre 2 bobine plasat pe placa ), l`am schimbat , acealasi lucru Intrebare , pot schimba mosfe-ti de pe spate cu altceva ? originalii(sau cel putin asta e in el acuma) sunt AP4415GH AP40T03GH am FDD8880 si FDD8889 pt N si pentru P , probabil o sa gasesc tot ceva asemanator , dar nu exact cu ce e in monitor acuma cel putin nu la VGS si R,ds si I mai maresau daca aveti idei despre defectul asta , ce sa mai verific , schimb Quote Link to comment Share on other sites More sharing options...
sebastian1970 Posted July 26, 2013 Share Posted July 26, 2013 adica ai imagine pe el si dupa o secunda se stinge de tot?ledul ramane aprins? Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 adica ai imagine pe el si dupa o secunda se stinge de tot?ledul ramane aprins?da o secunda imagine si se stinge imaginea de tot , intra in protectie , ledul se stinge si el , apas pe buton , iar acelasi lucru face Quote Link to comment Share on other sites More sharing options...
leoncris Posted July 26, 2013 Share Posted July 26, 2013 Verifica mai intai ... sursa. http://elektrotanya.com/philips_150s6-1 ... nload.html Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 Verifica mai intai ... sursa.http://elektrotanya.com/philips_150s6-1 ... nload.htmlpai sursa presupun ca ok , din moment ce porneste cu imagine cu tot pt o secunda oricum , mai specific , ce sa verific din sursa ? Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 rectific , led`ul ramane aprins dupa ce dispare imaginea idei ? Quote Link to comment Share on other sites More sharing options...
dan cod Posted July 26, 2013 Share Posted July 26, 2013 Verifica lampile mare probabilitate ca ele sa fie defecte. Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 Verifica lampile mare probabilitate ca ele sa fie defecte.Cea de jos se aprinde clar can porneste , in partea de sus e mai intunecat , suspectez ca aia ar fi pot inversa alimentarile ? sa o alimentez pe cea de sus in locul celei de jos , sa vad daca se aprinde ? Citisem ceva pe un forum din afara ca monitoarele astea se manifesta asa daca au mai putin de 11.5V e adevarat ? Quote Link to comment Share on other sites More sharing options...
leoncris Posted July 26, 2013 Share Posted July 26, 2013 De ce crezi ca am spus sa verifici ... sursa ?(tensiunile , evident)Verifica si CCFL_urile pe un inverter extern . Quote Link to comment Share on other sites More sharing options...
sebastian1970 Posted July 26, 2013 Share Posted July 26, 2013 am avut aceeas problema,era o lampa dusa,am schimbat lampa dar am reusit sa deslipesc banda aia cu multe contacte de la display.daca luminezi ecranul o sa vezi ca ai imagine pe el. Quote Link to comment Share on other sites More sharing options...
Gogured Posted July 26, 2013 Share Posted July 26, 2013 verifica invertoarele si lampile ...1 posibil tranzistori comanda invertor defect,2 posibil traf invertor defect,3 posibil lampa arsa....( mai putin probabil)succesuri ... Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 verifica invertoarele si lampile ...1 posibil tranzistori comanda invertor defect,2 posibil traf invertor defect,3 posibil lampa arsa....( mai putin probabil)succesuri ...Sursa e ok la tensiuni , trafuri invertor ok , lampile ok , raman doar cei doi mos-feti de pe spatele placii 9 il suspectez pe cel P-channeloriginalii(sau cel putin asta e in el acuma) sunt AP4415GH AP40T03GH acum revin la prima intrebare , merg inlocuiti cu ce am specificat mai sus ? cel putin cel N cu fdd8880 ?sau e nevoie de mosfe`ti exact la fel , la R,ds Vgs si Vds ? Quote Link to comment Share on other sites More sharing options...
Gogured Posted July 26, 2013 Share Posted July 26, 2013 pai mai intai verifica-i .... sa nu fie in scurt .... sau rezistenta mica zeci de ohmi ... direct in circuit cu un Ohmetru ...verifica si infasurarile trafo invertor ca rezistenta comparativ cu cel bun ....se pot pune orice tip de tranzistori daca au pinout-ul la fel si parametrii mai mari sau cel putin egali cu cei originali ... Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted July 26, 2013 Author Share Posted July 26, 2013 ok, mosfetul de pe N in circuit imi da bine , cel de pe P oricum as intoarte bornele de la aparat imi da aceleasi valori , deci sigur asta e parlit Quote Link to comment Share on other sites More sharing options...
Dr4g0n Posted August 7, 2013 Author Share Posted August 7, 2013 se dovedeste ca nu erau mos-feti arsi , nici vre unul din condensatorii electrolitici Dupa ce am schimbat tot ce era condensator electrolitic , m`am gandit totusi sa masor mai masor odata trafurile din invertor ( le masurasem doar secundarele prima data ) si uite asa am gasit unul dintre trafurile invertoare cu primarul intrerupt Acuma nu stiu de unde gasesc asa ceva sa cumpar din tara(nu ebay), ma poate ajuta cineva ?codul de pe el e it-e19-nb4004A Quote Link to comment Share on other sites More sharing options...
Join the conversation
