fane Posted August 23, 2006 Share Posted August 23, 2006 Am la reparat un Goldstar model CK21D10x ,la care sa dus memoria dupa o furtuna si as avea nevoie de un dump pt el. Procesorul este CXP851128 pe sasiu e scris PC31A 111-M55A(6) :prayer: Link to comment
fane Posted August 24, 2006 Author Share Posted August 24, 2006 multumesc TARA pentru ajutor. Link to comment
japan Posted August 20, 2011 Share Posted August 20, 2011 Buna ziua. Ca sa nu mai deschid un nou subiect am si eu un televizor Am la reparat un Goldstar model CK21D10x ,la care sa dusmemoria dupa o furtuna si as avea nevoie de un dump pt el.Procesorul este CXP851128 pe sasiu e scris PC31A 111-M55A(6) :prayer:tot Goldstar model CK21D10x procesorul este GS8434-01C pe sasiu e scris PC31A-111-M55A(4), as avea nevoie de schema lui, am cautat dar nu am gasit nimic. Multumesc anticipat. Link to comment
japan Posted August 20, 2011 Share Posted August 20, 2011 Salut uite schema aiciMultumesc, dar e in format PC31A.djvu si nu stiu cu ce program sa o vad. Un sfat daca se poate, multumesc. Am incercat cu mai multe programe dar nu o recunoaste. Link to comment
dan-a2 Posted August 20, 2011 Share Posted August 20, 2011 Instaleaza programul : djvu ! http://www.google.ro/search?q=djvu+down ... =firefox-a Link to comment
bobo Posted August 20, 2011 Share Posted August 20, 2011 asta este ce va trebuieps:e prea mare si nu merge.repede o adresa de mail si primiti exact schema de care aveti nevoiein format pdf Link to comment
FLORIN IORDACHE Posted August 20, 2011 Share Posted August 20, 2011 Va salut ! Aveti schema solicitata de dvs in format pdf .Succes ! Link to comment
