Jump to content
echivalent tranzistori s9014 ,s9015
  • Replies 3
  • Created
  • Last Reply
Top Posters In This Topic
Popular Days
In asteptarea raspunsurilor de la cei experimentati in domeniul audio, imi dau si eu cu parerea, dupa ce m-am uitat pe foile tehnice ale tranzistorilor.
S9014 : http://pdf1.alldatasheet.com/datasheet- ... S9014.html
Este un tranzistor dedicat in preamplificare, cu zgomot redus si linearitate a hFE.
BC547 : http://www.play.com.br/datasheet/BC547.pdf
Nu se poate lauda cu zgomot redus. Din familia lui, BC549 are zgomot redus dar are tensiune de functionare cu mult mai mica decat S9014.
Parerea mea este ca nu prea merge inlocuit cum vrei tu.
Link to comment
Join the conversation
Guest
Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
  • Create New...
Important Information
