bogdy00007 Posted August 9, 2006 Share Posted August 9, 2006 sal, am un samsung, nu stiu ce model ca e la tara,e mai vechi ,la cere i-am schimbat de 2 ori cond(100uF/400V) de la sursa si se tot arde.care ar putea fi problema?merci. Link to comment Share on other sites More sharing options...
Tavi Posted August 9, 2006 Share Posted August 9, 2006 tensiune mare la retea ... ia vezi tu cand mergi acolo Link to comment Share on other sites More sharing options...
bogdy00007 Posted August 9, 2006 Author Share Posted August 9, 2006 se poate as fie si din cauza ca priza are contact imperfect? Link to comment Share on other sites More sharing options...
I.Dani83 Posted August 9, 2006 Share Posted August 9, 2006 Nu am vazut condensator ars pana acum .Poate doar explodat , strapuns .Pune unul de 220uF la 400V si spune-i la bunicu` sau vecinu ca pe reteaua lor de tensiune exista si televizoare nu numai motoare fara condensatoare compenasatoare de factor de putere si instalatie adecvata de pornire. Link to comment Share on other sites More sharing options...
bogdy00007 Posted August 9, 2006 Author Share Posted August 9, 2006 multumesc de raspunsuri,alte cauze in afara de retea nu ar mai putea fi?mereci.numai bine! Link to comment Share on other sites More sharing options...
PETRE66 Posted August 10, 2006 Share Posted August 10, 2006 Nu am vazut condensator ars pana acum .Poate doar explodat , strapuns .Pune unul de 220uF la 400V si spune-i la bunicu` sau vecinu ca pe reteaua lor de tensiune exista si televizoare nu numai motoare fara condensatoare compenasatoare de factor de putere si instalatie adecvata de pornire. cum arata un condensator ars ??!!! .....asta e ceva nou Link to comment Share on other sites More sharing options...
bogdy00007 Posted August 10, 2006 Author Share Posted August 10, 2006 am zis "ars" in sens generic, adica nu este ars propri-zis fizic ci functional. Link to comment Share on other sites More sharing options...
Tavi Posted August 10, 2006 Share Posted August 10, 2006 pana la urma care e faza cu acest condensator, de ce il schimbi mereu ? Link to comment Share on other sites More sharing options...
bogdy00007 Posted August 10, 2006 Author Share Posted August 10, 2006 deci prima data cand s-a stricat tv-ul nu mai pornea si stiam ca la samsung e defect tipic cond de pe sursa ,deci l-am scimbat si a mers normal,dupa 2 saptamani s-a intamplat la fel si l-am schimbat si a mers din nou si acum e a treia oara cand face la fel si ma intrebam de ce se tot duc conzii.daca ma putetia juta cu o solutie,va multumesc mult. Link to comment Share on other sites More sharing options...
vali2006 Posted August 10, 2006 Share Posted August 10, 2006 Vezi tu nu cumva ai avut o rezistenta de 2-4 ohmi pe langa puntea redresoare pe care ai inlocuit-o cu un cui (0 ohmi).Asta ar putea provoca fenomenul ca urmare a faptului ca apare un curent mare de incarcare la pornirea din intrerupator. Link to comment Share on other sites More sharing options...
bogdy00007 Posted August 10, 2006 Author Share Posted August 10, 2006 nu am schimbat rezistenta. Link to comment Share on other sites More sharing options...
PETRE66 Posted August 10, 2006 Share Posted August 10, 2006 deci prima data cand s-a stricat tv-ul nu mai pornea si stiam ca la samsung e defect tipic cond de pe sursa ,deci l-am scimbat si a mers normal,dupa 2 saptamani s-a intamplat la fel si l-am schimbat si a mers din nou si acum e a treia oara cand face la fel si ma intrebam de ce se tot duc conzii.daca ma putetia juta cu o solutie,va multumesc mult. conzi se unfla ,curg sau pierd din capacitate ?? Esti cam ambigu in exprimare. se mai distrug alte piese ?? :rolleyes: Link to comment Share on other sites More sharing options...
Tavi Posted August 10, 2006 Share Posted August 10, 2006 eu cred ca tu schimbi condensatoul ala ca sa il schimbi, uscat e altul, care dupa ce incalzesti zona se mai incalzeste si el si porneste televizorulnu ste posibil ca sa se usuce filtrajul pe 300V in 2 saptamani nici daca il pui la plaja Link to comment Share on other sites More sharing options...
Marele Savant Posted August 10, 2006 Share Posted August 10, 2006 Schimba condens. electrolitice din primarul sursei ! Imposibil nu este nici ca cele noi sa fie proaste, eu am la job 100 de buc de 100/400 noi noute, cu ESR mare adica indica cit unele de 1 micro si sint inutilizabile. Link to comment Share on other sites More sharing options...
q_acdc Posted August 10, 2006 Share Posted August 10, 2006 condesatorul schimbat nou este de fapt vechi( de productie mai veche),sau BO ia curent mai mare , incearca sa schimbi puntea redresoare(diodele ) Link to comment Share on other sites More sharing options...
Archived
