Jump to content
Sign in to follow this
mpredusca_70
transformator genius
salut,am si eu un transformator de genius cu probleme si as vrea sa achizitionez altul si nu prea il gasesc.caracteristicile tr sunt;primar230v;sec2x27v,2,8A si13,5v,1,9A.daca ma poate ajuta cineva multumesc anticipat
Share this post
Link to post
Share on other sites
Ce probleme are?Daca e primarul intrerupt atunci verifica siguranta termica din el, o gasesti sub izolatie.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
