Guest Mihaita Balea Posted April 9, 2013 Share Posted April 9, 2013 Va salut pe toti membrii acestui forum.Sunt inregistrat nou pe acest forum si nu stiu cumcum se procedeaza,dar am o probleme cu BV. la tv Buntz model STV 2101 cu ci STV 8172L.Se defecteaza dupa vreo 3-5 min.Am tens alim.+/- 14,5v si l-am inlocuit cu:TDA 8172,STV9302A si LA78040,toate sau ars.Va rog frumos sa ma ajutati cu schema sau cu rezolvarea problemei.Este echipat cu jungla TDA11135PS,STV8172L,CD7523CS.Bobina de deflectia are 8-9 ohmi. Va multumesc mult Link to comment Share on other sites More sharing options...
BUGHIU Posted April 9, 2013 Share Posted April 9, 2013 C404 l-ati schimbat?!?! Este intre pinul 6 si 3!! De asemenea schimbati si dioda VD401 dintre pinii 2 si 6!! Link to comment Share on other sites More sharing options...
tehtronics Posted April 9, 2013 Share Posted April 9, 2013 schimba C-ul montat intre pinii 3 si 6 ai CI cadre Link to comment Share on other sites More sharing options...
Guest Mihaita Balea Posted April 9, 2013 Share Posted April 9, 2013 Am schimbat ambele piese,d451 si c451 cum sunt notate pe placa.Este posibil sa fie bobina de vina,deorece nu se incalzete prea tare,aproximativ 50 grade. Va multumesc Link to comment Share on other sites More sharing options...
dan cod Posted April 10, 2013 Share Posted April 10, 2013 Verifica si conzii ceramici din zona BVului.Cum se strica CIul?intra in scurt?sau cum? Link to comment Share on other sites More sharing options...
palcu ion Posted April 10, 2013 Share Posted April 10, 2013 masoara tensiunea de alimentare cadre,sa nu fie prea mare,nu stiu acum ce sasiu este,verifica totusi in sursa daca exista un tranzistor A1015 atunci trebuie inlocuit cu A1013,acela face multe probleme Link to comment Share on other sites More sharing options...
Archived
