Jump to content
Sign in to follow this
legionaru
tv AKAY cu procesor TDA11126PS/V3/3
sasiu china echipat cu procesorul TDA11126PS/V3/3 pe el are lipita o eticheta NT11126PC 301CG. am montat memorie goala fara nici un rezultat, aceiasi problema... as dori un dump daca are cineva, multumesc!
Share this post
Link to post
Share on other sites
buna. am nevoie de tip model televizor si sasiu. am un damp pe asest tip de procesor dar alt model de televizor(westwood) incearca a urmari circulatia de date intre procesor si memorie. :sparge:
Share this post
Link to post
Eu le detin pe astea AKAI 1417D AKAI 1417D (430 Byte) AKAI 14CT01 AKAI 14CT01 (630 Byte) AKAI 14WKDT AKAI 14WKDT (1.3 KB) AKAI 15CT22FS chassis PX20045 AKAI 15CT22FS chassis PX20045 (380 Byte) AKAI 2007 AKAI 2007 (557 Byte) AKAI 20WKD AKAI 20WKD (1.4 KB) AKAI 2107D AKAI 2107D (980 Byte) AKAI 2119 AKAI 2119 (412 Byte) AKAI 21CT215 AKAI 21CT215 (508 Byte) AKAI 21CT32FSR AKAI 21CT32FSR (734 Byte) AKAI 21CT32FSR AKAI 21CT32FSR (641 Byte) AKAI 21CTS84FSN AKAI 21CTS84FSN (2.2 KB) AKAI 21CTS92FS AKAI 21CTS92FS (625 Byte) AKAI 21KW AKAI 21KW (555 Byte) AKAI 25CT23FSR AKAI 25CT23FSR (484 Byte) AKAI 29CT23FSR AKAI 29CT23FSR (551 Byte) AKAI 29CT24FS CH-1 AKAI 29CT24FS CH-1 (534 Byte) AKAI C-142KER AKAI C-142KER (154 Byte) AKAI CK-14WKDT AKAI CK-14WKDT (1.1 KB) AKAI CP-71S1 AKAI CP-71S1 (614 Byte) AKAI CT-1402 AKAI CT-1402 (528 Byte) AKAI CT-1407D AKAI CT-1407D (439 Byte) AKAI CT-1417D AKAI CT-1417D (450 Byte) AKAI CT-1419A AKAI CT-1419A (578 Byte) AKAI CT-1419D AKAI CT-1419D (529 Byte) AKAI CT-14WKD AKAI CT-14WKD (475 Byte) AKAI CT-14WR AKAI CT-14WR (410 Byte) AKAI CT-2012P AKAI CT-2012P (314 Byte) AKAI CT-2019D AKAI CT-2019D (408 Byte) AKAI CT-20WKD AKAI CT-20WKD (602 Byte) AKAI CT-20WKDT AKAI CT-20WKDT (539 Byte) AKAI CT-2102P AKAI CT-2102P (314 Byte) AKAI CT-2110TXT AKAI CT-2110TXT (361 Byte) AKAI CT-2119 AKAI CT-2119 (415 Byte) AKAI CT-2119D AKAI CT-2119D (507 Byte) AKAI CT-2159 AKAI CT-2159 (387 Byte) AKAI CT-2159PT AKAI CT-2159PT (387 Byte) AKAI CT-21WKD AKAI CT-21WKD (348 Byte) AKAI CT-24FS chassis CH-1 AKAI CT-24FS chassis CH-1 (534 Byte) AKAI CT-2867UNT AKAI CT-2867UNT (289 Byte) AKAI CT-2885F AKAI CT-2885F (950 Byte) AKAI CT-34S43A A81DC AKAI CT-34S43A A81DC (431 Byte) AKAI CT-G140D AKAI CT-G140D (265 Byte) AKAI CT-G1410E AKAI CT-G1410E (564 Byte) AKAI CT-G1420E AKAI CT-G1420E (751 Byte) AKAI CT-G2105E AKAI CT-G2105E (682 Byte) AKAI CT-G2109E AKAI CT-G2109E (1.9 KB) AKAI CT-G2120E AKAI CT-G2120E (778 Byte) AKAI CT-G2122E AKAI CT-G2122E (546 Byte) AKAI CT-G2133E AKAI CT-G2133E (853 Byte) AKAI CT-G215 AKAI CT-G215 (181 Byte) AKAI CT-G2199E AKAI CT-G2199E (867 Byte) AKAI CT-G2199FT AKAI CT-G2199FT (1.7 KB) AKAI CT-G2501E AKAI CT-G2501E (671 Byte) AKAI CT-G255D AKAI CT-G255D (311 Byte) AKAI CT-T212NT AKAI CT-T212NT (381 Byte) AKAI CT-T34S4HA AKAI CT-T34S4HA (504 Byte) AKAI CT-V282NTF-E10 chassis 11AK37 AKAI CT-V282NTF-E10 chassis 11AK37 (592 Byte) AKAI CT-W1403E (11AK36-1) AKAI CT-W1403E (11AK36-1) (630 Byte) AKAI CT-W2105ET-PIP AKAI CT-W2105ET-PIP (770 Byte) AKAI LM-E15CCSA AKAI LM-E15CCSA (471 Byte) AKAI MP2-37H1 AKAI MP2-37H1 (895 Byte) AKAI PDP42TD1 AKAI PDP42TD1 (653.6 KB) AKAI SP71S1 AKAI SP71S1 (943 Byte) AKAI ST21W32D AKAI ST21W32D (755 Byte) AKAI VS465EDG AKAI VS465EDG (2.2 KB) AKAI VSF16 AKAI VSF16 (220 Byte) AKAI VSF260EDG AKAI VSF260EDG (584 Byte) AKAI VSF33EOG-V AKAI VSF33EOG-V (499 Byte) AKAI-CTG 2110Е AKAI-CTG 2110Е (2.0 KB) Akai 15CT22F5 сhassis PX20045-6GG Akai 15CT22F5 сhassis PX20045-6GG (678 Byte)
Share this post
Link to post
Vezi ca ai probleme cu 5V alimentare memorie de aceea face asa.
Share this post
Link to post
Din ce scrie autorul eu inteleg ca problema acestui tv este faptul ca procesorul are lipita pe el o eticheta.Ca s-o dezlipeasca a pus memorie noua dar "fara niciun rezultat,aceiasi problema" eticheta e tot lipita si vrea sa incerce cu alt dump.Dancod spune ca din cauza tensiunii de 5v nu se dezlipeste.Fratilor,nu credeti ca oferiti solutii fara sa stim defectul?Rezolvarea aceasta nu va fi de folos nimanui altcuiva daca nu stim manifestarea.
Share this post
Link to post
Are dreptate dl Coman Ion,ce defect este ala"aceiasi problema" , cum se intelege asta?
Share this post
Link to post
E curios ca in primul post se spunea ca nu tine minte programele.Unde a disparut asta chiar e curios.Deci de la raspunsul nostru a intervenit ceva ,,pe traseu,,
Share this post
Link to post
tv AKAY nu tine minte posturile memorate- asta era titlul topicului; a fost modificat de admin, si de aceea nu se mai intelege manifestarea defectului. sa il mai expun o data: dau cautare automata, gaseste toate posturile, le memoreaza pe moment, dupa care chiar daca il las sa functioneze , unele canale nu mai sunt, doar ecran albastru; raman cateva aiurea... asta e defectul! tensiunea de 5v e ok!
Share this post
Link to post
Intre AKAI si AKAY exista o mica/ mare diferenta > poate gasiti un dump original ptr. procesorul din tv.> sau proc. defect !!
Share this post
Link to post
Nu cumva e tunerul prost si fuge din frecventa? Succes
la asta nu m-am gandit dar e foarte posibil; am incercat sa-i reglez AGC din sm si nu se simte nimic pe imagine; am omis sa spun ca posturile care raman memorate sunt cele cu semnal bun dar la schimbarea canalelor apar cu vajait, fara sonor dupa 3-4 sec vine sonorul si imaginea nu-i tocmai buna fiind necesar fine tuning-ul. cred ca l-am diagnosticat gresit la inceput cerand un dump, dar, din greseli invata omul...
Share this post
Link to post
Vin si eu cu o varianta intalnita la sasie China si usor de verificat :tensiunea de 33v pentru varicap.Fac pariu ca se balangane intre 29,5 si 29,9 v.De vina e stabilizatoarea de 33v.
Share this post
Link to post
Intre AKAI si AKAY exista o mica/ mare diferenta > poate gasiti un dump original ptr. procesorul din tv.> sau proc. defect !!Legeonarule este Akai sau Akay? Eu nu am intalnit Akay, da-ti o cautare pe google sa vedeti daca exista vreo referire la modelul Akay. Daca gasiti pe mine va rog sa ma scuzati, nimeni nu le stie pe toate.Eu am avut acest defect si am gasit contact imperfect pe trasul de 5v, dar tu ai zis ca e ok.
Share this post
Link to post
Dumpul il postez eu desi nu cred ca va ajuta in cazul asta.Eu sunt sigur ca are ceva defect acolo.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
