Jump to content
alex tm
Intrebare router DWL-7100AP
O banala cautare pe google avand ca termen de cautare "D-link DWL-7100AP pret" a scos pagina asta in cale :
http://www.compari.ro/routere-c3144/d-l ... ap-p35941/
iar acolo ai doua link-uri cu Spre Magazin:
http://www.oktal.ro/access+point/d-link ... 16944.html
http://www.evomag.ro/RETELISTICA-Access ... -Mbit.html
Acealasi teremen de cautare alt linc pe price.ro :
http://www.price.ro/preturi_d-link_dwl-7100ap_34685.htm
A fost greu ?
Link to comment
Share on other sites
O banala cautare pe google avand ca termen de cautare "D-link DWL-7100AP pret" a scos pagina asta in cale :http://www.compari.ro/routere-c3144/d-l ... ap-p35941/iar acolo ai doua link-uri cu Spre Magazin:http://www.oktal.ro/access+point/d-link ... 16944.htmlhttp://www.evomag.ro/RETELISTICA-Access ... -Mbit.htmlAcealasi teremen de cautare alt linc pe price.ro :http://www.price.ro/preturi_d-link_dwl-7100ap_34685.htmA fost greu ?
Nu, sincer am gasit asta, dar ma gandeam ca preturile nu sunt actualizate!Nu credeam ca e asa scump..Iti multumesc!
Link to comment
Cu placere !
Uite aici specificatiile :
Standards
IEEE 802.11g
IEEE 802.11b
IEEE 802.11a
IEEE 802.3
IEEE 802.3u
Media Access Control
CSMA/CA with ACK
Ethernet Port
10/100BASE-TX Ethernet port
Wireless Frequency Range *
802.11b/g: 2.4 to 2.4835GHz
802.11a: 5.150 to 5.8750GHz
* Software configurable as allowable frequency will vary among different countries in the European region.
Wireless Data Rates (With automatic fallback)
54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 11Mbps, 9Mbps, 6Mbps, 5.5Mbps, 2Mbps, 1Mbps
Modulation Technology
802.11a/g: BPSK, QPSK, 16QAM, 64QAM, OFDM
802.11b: DQPSK, DBPSK, DSSS, CCK
Security
64/128/152-bit WEP
802.1x
WPA: Wi-Fi Protected Access (64/128/152-bit WEP with TKIP, MIC, IV Expansion, Shared Key Authentication)
Advanced Encryption Standard (AES) support
Antennas
Dual non-detachable dipole external antennas:
For 2.4GHz: 2dBi Gain antenna
For 5GHz: 2dBi Gain antenna
Dual PIFA internal antennas:
Wireless Operating Range *
Indoors: up to 100 m (328 feet)
Outdoors: up to 400 m (1,312 feet)
* Environmental conditions may adversely affect wireless signal range
Receive Sensitivity
802.11a (1000-byte PDUs @ 10% PER):
87dBm for 6Mbps
86dBm for 9Mbps
85dBm for 12Mbps
83dBm for 18Mbps
80dBm for 24Mbps
76dBm for 36Mbps
71dBm for 48Mbps
66dBm for 54Mbps
73dBm for 108Mbps (Turbo Mode)
802.11b (@ 8% PER):
83dBm for 11Mbps
89dBm for 2Mbps
802.11g (1000-byte PDUs @ 10% PER):
87dBm for 6Mbps
86dBm for 9Mbps
85dBm for 12Mbps
83dBm for 18Mbps
80dBm for 24Mbps
76dBm for 36Mbps
71dBm for 48Mbps
66dBm for 54Mbps
Transmit Output Power
802.11a:
14 to 15dBm @ 54Mbps
14 to 16dBm @t 48Mbps
16 to 18dBm @t 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps
802.11b:
18dBm @ 11Mbps, 5.5Mbps, 2Mbps, 1Mbps
802.11g:
14 to 15dBm @ 54Mbps, 108Mbps
14 to 16dBm @ 48Mbps
16 to 18dBm @ 36Mbps, 24Mbps, 18Mbps, 12Mbps, 9Mbps, 6Mbps
Diagnostic LEDs
Power
10Mbps (Link/Act)
100Mbps (Link/Act)
WLAN 802.11b/g
WLAN 802.11a
Device Management
Web-based: Internet Explorer v6 or later; Netscape Navigator v6 or later; or other Java-enabled browsers
DHCP client
Factory reset button
Physical & Environmental
Power Input
DC 5V, 2A
Through external power adapter
Dimensions
192 mm (W) x 118 mm (D) x 31 mm (H) (device only)
Weight
280 grams (device only)
Operating Temperature
0° to 55 °C (32° to 149 °F)
Storage Temperature
-20° to 75 °C (4° to 167 °F)
Humidity
95% maximum (non-condensing)
Emission (EMI)
FCC Class B
CE Class B
C-Tick
Safety
CSA International
Ordering Information
DWL-7100AP
802.11a/g Wireless LAN Access Point
Please specify your model number as follows:
DWL-7100AP/BEU
For UK, Ireland
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
