Jump to content
marianx
Intrebare driver 4 axe TB6560
Va salut!
Am cumparat de pe hi-end.ro driverul acesta http://www.hi-end.ro/driver-cnc-pe-4-axe-3a-bipolar-p-2625.html.
Inca nu l-am alimentat, deoarece, ca toate driverele chinezesti facute cu acest integrat (TB6560), placa nu respecta specificatiile producatorului cipului:
1. Power-on Sequence with Control Input Signals
Turn on VDD. Then, when the VDD voltage has stabilized, turn on VMA/B.
Hold the control input pins Low while turning on VDD and VMA/B.
(All the control input pins are internally pulled down.)
After VDD and VMA/B completely stabilizes at the rated voltages, the RESET and ENABLE pins can be
set High. If this sequence is not properly followed, the IC may not operate correctly, or the IC and the
peripheral parts may be damaged.
When RESET is released High, the CLK signal is applied and excitation is started. Only after ENABLE
is also set High, outputs are enabled. When only RESET is set High, outputs are disabled and only the
internal counter advances. Likewise, when only ENABLE is set High, the excitation will not be performed
even if the CLK signal is applied and the outputs will remain in the initial state.
An example of a control input sequence is shown below.
A power-off sequence should be the reverse of this sequence.
Pe placa driverului, tensiunea de 5V se obtine din reducerea tensiunii de 24V; aceasta este trecuta prin 2 CI stabilizatoare de 12v si in final 5v.
Din cate am mai citit, asta pare sa fie principala cauza a deteriorarii integratului driver, deoarece la start apar regimuri tranzitorii in care se poate intampla ca ambele FET-uri din final sa conduca, ducand la scurt circuit si implicit arderea integratului.
Pe scurt (daca se poate numi asa dupa cat am scris mai sus), intrebarea este daca e suficient sa respect doar aceasta parte din secventa de start, fara partea cu pinii RESET (unde are doar un condensator la masa si o rezistenta pe 5v) si ENABLE (care poate fi eventual mentinut LOW din MACH3)?
Sa folosesc 2 alimentatoare separate nu ar fi o problema, unul de 5v pentru partea de comanda si pentru 24v un altul separat, pe care il pornesc ultimul (asta daca nu uit, e destul de complicat de automatizat acest aspect din cauza sarcinilor inductive, dar nu imposibil).
Multumesc pentru rabdare si scuze pentru cantitatea de text de mai sus.
Link to comment
Share on other sites
Nu merge asa usor, pe contactele releului vor exista descarcari de tensiune inalta, generata de bobinele motoarelor, si in plus, pentru oprirea tensiunilor trebuie reluata operatiunea in sens invers, tensiunea de 24v prima apoi cea de 5v.Se poate pune releul pe alimentarea cu 220v a alimentatorului de 24v, dar asta rezolva doar problema sarcinilor inductive.Practic trebuie construit un temporizator cu PIC sau chiar si CI logice pentru alimentare, dar mi se pare prea complicat. Tot 2 butoane sunt mai practice, marcate clar si respectata ordinea de oprire si pornire.Eu asa il voi alimenta, sper sa fie suficient de sigur pentru driver; din cate am citit pe alte forumuri, asta pare sa fie marea problema la acest integrat, se arde la start.
Link to comment
caun un electronist ptr. o posibila colaborare.In viitorul apropiat vreu sa construiesc o masina cnc cu fir cald.Acesta este e-mail-ul meu [email protected]
Eu nu mai profesez de ceva timp, dar daca te pot ajuta cu un sfat pot incerca, eventual aici pe forum. Nu am experienta in CNC-uri, abia acum sunt in stadiul de construire a primului meu CNC, de 1 luna tot citesc documentatii despre ele, aproape am terminat mecanica.
Link to comment
Am alimentat driverul si testat, merge bine. Acum am observat ca are o protectie pe bara de 24v, un tranzistor darlington care pune tensiunea in scurt monitorizand iesirea stabilizatorului de 12v, respectand in felul acesta, macar partial, secventa de oprire (se poate arde totusi daca exista condensatoare mari de filtraj pe 24v).Eu am scos stabilizatorul de 5v si am folosit doua surse de alimentare, una de 5v care functioneaza permanent si una reglabila (12-24v / 1-3A) pe care o folosesc pentru motoare si pe care o pornesc si opresc prima.Nici macar nu se incalzesc radiatoarele integratelor, la amperajul minim, e adevarat (0,6A) si la 15v. Am folosit motoare mici, de 0,8A. N-am reusit sa scot ca viteza din aceste motoare mai mult de 250mm/min (in Mach 3), mai mult de atat incep sa piarda pasi. Motoarele sunt recuperate din imprimante laser vechi (KH56JM...). Cu fisierul de configurare descarcat de pe hi-end.ro, kernelul era setat la 45KHz, am observat ca la 25KHz sunt si mai lente motoarele; L-am ridicat la 60KHz si inca merge bine. Nu am inteles de ce o fi bifat "Sherline 1/2 pulse mode" - am incercat fara si merg rau motoarele, cu el bifat e ok. Va trebui sa ma documentez ce e cu asta.Va trebui sa incerc si cu EMC2 (acum LinuxCNC, parca) sa vad daca se comporta la fel. Pentru CNC-ul meu din bare de otel cu rulmenti 608 si suruburi de constructii :) pare sa fie perfect acest driver (pana acum, in teste, cel putin).Oare motoarele sunt cauza limitarii vitezei?
Link to comment
Guest Florian Serbu
Sal,eu am lucrat la o mica firma ca si vopsitos de litere volumetrice,si asta acum mai bine de 10 ani,si sincer sa fiu nici nu mai stiu exact dimensiunile masinii,dar era marisoara,imi aduc aminte,ptr.ca prelucra si blocuri mai mari de expandat.Eu as vrea sa fac tot ceva mai marisor dar trebuie sa ma interesez cam la ce marimi sa o fac pentru a cumpara profilele de aluminiopentru cadru,dupa asta am sa vad ce fac de drivere,si am sa ma uit ptr.5 motoare cu siguranta.
Link to comment
Pentru taiat polistiren cu fir incins nu-ti trebuie motoare puternice, ca n-ai sarcina mare.
Link to comment
Guest Florian Serbu
Da,cu siguranta,mai ales ca ma uitam la curele ptr. transmisie
Link to comment
Guest Florian Serbu
Am facut si eu cateva masini de taiat polistiren.
Ultima va fi gata in 2-3 saptamani.
Ai nevoie de driver?
Daca se poate ,nu mi-ar veni rau poate asa ma pun pe treaba,PTR.ca pana acum nu am facut nimic.
Si inca ceva ,vreau sa fac o socoteala la profilele de aluminiu,sa vad cam cati metri mi-ar trebui ca sa cer preturi la BOSCH . La ce marime crezi ca ar fi deajuns ca sa pot lucra si blocuri mai marisoare de poliexpantat?
Multumesc.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
