petrenou Posted February 23, 2013 Share Posted February 23, 2013 Am acets tv la reparat si tens U1 este 117v fara sa fie conectat baleajul orizontal iar cand apas p+ ca sa conectez si orizontalul imi coboara la 80v.Cei 2 cond de 47u inlocuiti,final linii inlocuit .Sa fie trafu de linii,problema e ca nu am cu ce sa verific. Link to comment
giany Posted February 23, 2013 Share Posted February 23, 2013 verifica mai intai pe bec sa vezi daca tine sursa in consum tensiuna de 117v iar apoi incearca si cu deflexia h decuplata daca sursa este buna, daca trafo linii iti scade aceasta tensiune ar trebui sa se incalzeasca tare tz.final linii Link to comment
modoran Posted February 23, 2013 Share Posted February 23, 2013 Sursa tine in sarcina ? Cu un bec in loc de final linii u1 este corecta ? Link to comment
petrenou Posted February 23, 2013 Author Share Posted February 23, 2013 U1 cu bec este 119v,am deconectat si bobinele h si tot nu porneste,sta cam 6sec pornit (adica cam atat comanda final de linii)dupa care se opreste ,dupa ce se opreste am pus degetul pe final si cam frige. Link to comment
petrenou Posted February 23, 2013 Author Share Posted February 23, 2013 As mai putea face ceva ca sa fiu sigur ca e trafu? Link to comment
dan cod Posted February 23, 2013 Share Posted February 23, 2013 Sa il testezi .Daca nu ai cu ce e greu.Eventual verifica sa nu ai scurt in eecundarele lui. Link to comment
petrenou Posted April 1, 2013 Author Share Posted April 1, 2013 Tv rezolvat problema a fost scurt d804. Link to comment
petrenou Posted April 12, 2013 Author Share Posted April 12, 2013 Ar mai fi o problema,nu afiseaza osd pe ecran si nu pot cauta programele procesorul este sda20581-a504. Link to comment
petrenou Posted April 13, 2013 Author Share Posted April 13, 2013 Nu are nimeni nici o idee ce as putea sa verific? Link to comment
petrenou Posted April 15, 2013 Author Share Posted April 15, 2013 Mai are o dungulita verticala in partea stanga cam de 4cm dar este transparenta si nu am idee de unde ar putea sa vina. Link to comment
Toni Marginean Posted April 15, 2013 Share Posted April 15, 2013 Intoarcerea pe linii se datoreaza reglajului de faza pe H. Link to comment
petrenou Posted April 15, 2013 Author Share Posted April 15, 2013 Rastrul se vede pe tot ecranul doar in partea stanga apare o dunga prin care se vede pureci dupa cum se vede si in poza. Link to comment
dan cod Posted April 15, 2013 Share Posted April 15, 2013 In poza se vad 5 dungi cu pureci si imagine deloc.Nu-i poate poza concludenta. Link to comment
petrenou Posted April 15, 2013 Author Share Posted April 15, 2013 Pe imagine acele dungi nu se vad doar in poza se vad,ce se vede este un rastru cu pureci cu o dunga vericala in stg prin care se vad pureci in poza se vede mai greu dar date va uitati mai bine se observa.Varicapul la acest selector se face prin sda si scl? Link to comment
dan cod Posted April 15, 2013 Share Posted April 15, 2013 Poate filtraj pe 200V ,poate condul de 100uF din BV oricum ceva cond acolo devalorizat.Dupa mine. Link to comment
