Guest amircea_ro Posted December 12, 2012 Share Posted December 12, 2012 Buna ziua.Sunt posesorul unui TV Grundig 37-7750FHD.Daca stie cineva ce este defect, in cazul in care pe ecran apare imaginea atasata.Precizez ca defectul apare cind pornesc televozorul de la telecomanda,in special la prima pornire din zi.Daca nu porneste ,il opresc de la butonul general ,dupa care porneste ok.L-am facut bucati ,am verificat alimentarile,am verificat toatre conexiunile ,inclusiv cei 12 conectori ai panelului LCD .L-am pornit desfacut, am miscat toate cablurile , toti conectorii si merge perfect,nu schiteaza nici macar o intrerupere.Ar fi binevenita si o schmea ,daca are cineva.Multumesc Link to comment Share on other sites More sharing options...
popa ionut Posted December 12, 2012 Share Posted December 12, 2012 Alimentare insuficenta modul T-CON,ori Panel defect.poate chiar defect t-con ..observ ca nu are nici imagine decat acele dungi...ceea ce ma duce mai repede la un t-con defect..pune o poza cu modulul t-con si ceea ce scrie pe panel. Link to comment Share on other sites More sharing options...
Guest amircea_ro Posted December 12, 2012 Share Posted December 12, 2012 panelul este AUO T370HW02-V2.am si poza cu T_CON-ul ,dar doar cind ajung acasa.Multumesc Link to comment Share on other sites More sharing options...
leoncris Posted December 12, 2012 Share Posted December 12, 2012 Este sasiu BEKO G2 http://elektrotanya.com/grundig_digi200 ... nload.html Link to comment Share on other sites More sharing options...
Guest amircea_ro Posted December 13, 2012 Share Posted December 13, 2012 Am atasta o poza cu T-CON-ulMultumesc Link to comment Share on other sites More sharing options...
popa ionut Posted December 14, 2012 Share Posted December 14, 2012 Schimba modulul T-con,au probleme cele de la AUO Link to comment Share on other sites More sharing options...
Guest amircea_ro Posted December 14, 2012 Share Posted December 14, 2012 ai idee unde gasesc un modul t-con?Multumesc Link to comment Share on other sites More sharing options...
Archived
