TIMIS STEFAN Posted November 28, 2012 Share Posted November 28, 2012 Am un Tv Hundai Porneste din STAND BY U in colector BU 808 = 146V U in tranzistor prefinal linii = 0.V Am intrerupt rezistenta care vine cu impulsuri linii si tot 0.V am in colector prefinal linii. (2SK3065)Va rugam da ti-mi un raspuns. Link to comment
dan cod Posted November 28, 2012 Share Posted November 28, 2012 Pai verifica de unde scoate tensiunea de alimentare driver .Ai acolo ceva intrerupt. Link to comment
TIMIS STEFAN Posted November 28, 2012 Author Share Posted November 28, 2012 Pai verifica de unde scoate tensiunea de alimentare driver .Ai acolo ceva intrerupt.Am u = 9 v dar cand cuplez rezistenta pe tranzistor scade la 0v merci Link to comment
dan cod Posted November 28, 2012 Share Posted November 28, 2012 9V alimentare driver oricum este putin ,schimba filtrajul pe tensiunea asta.Ar trebui sa ai acolo macar un 14V. Link to comment
belowsky Posted November 28, 2012 Share Posted November 28, 2012 Tre sa ne dai si un model, pe langa marca,sa stim ce sasiu e,ca sa urmaresti in schema. Link to comment
TIMIS STEFAN Posted November 28, 2012 Author Share Posted November 28, 2012 9V alimentare driver oricum este putin ,schimba filtrajul pe tensiunea asta.Ar trebui sa ai acolo macar un 14V.In schema e 9v modelul asta de tv este fara trafo driver are in prefinal 2 tranzistoare bc 848 si un MOS-FET 2sc 3065 merciitv hyundai model nr 20 b 9 m 14-txs Link to comment
leoncris Posted November 28, 2012 Share Posted November 28, 2012 Sasiu Beko 12.6Ai masurat rezistenta R517 ?Schimba C512 si BU 808DFI si mai vedem. Link to comment
Marian C Posted November 28, 2012 Share Posted November 28, 2012 pai in stand by ar trebui sa ai 118v in colector bu808, vezi sursa pe bec si cond filtraj pe ramura de 9v Link to comment
Marian C Posted November 28, 2012 Share Posted November 28, 2012 dupa reparatie te rog mult valorile pt: AGC, 2.AGC, R.CUT, G.CUT, B.CUT, R.DRV, B.DRV, SCRN, SECBL, AFT38 si ATF33.Mentionez ca se intra in service menu apasand tasta "menu" apoi 8500 (si se iese cu tasta 0), dupa care tastele colorate , rosu, verde, galben, albasru. (4 submeniuri ).Dupa ce ai intrat in submeniuri pt siguranta mai intai noteaza valorile pe o hartie, ca daca din greseala apesi tastele de volum se schimba valorile si nu mai sti cele initiale.Mersi mult Link to comment
belowsky Posted November 28, 2012 Share Posted November 28, 2012 Am patit la un sasiu de asta,ca era blocat fet-ul driver,l-am scos afara sa-l masor la impedanta mare,arata bun ,,l-am pus inapoi , a pornit:) ,si de atunci merge. Link to comment
TIMIS STEFAN Posted December 6, 2012 Author Share Posted December 6, 2012 Am un tv HIUNDAY in sursa tda16846 procesor sda5535 procesor video nn 5198k sursa porneste b+ 146V toate tensiunile bune tv nu porneste u in baza t507=0,6v pe pin 42 nn 5198k 1,3v vreo sugestie La alt tv Arctic tot aceleasi componente nu porneste sursa am schimbat tranzistorul integratul cooperul si cond. electrolitice totul este ok dar nu porneste am decuplat si esirile din secundar u pe integrat pe pin 2.2,6v pe pin 11.2,9v pe pin 14.2,5v R 806 R808 sint bune D806 pe cond. filtraj in jur de 300v poate cineva sa ma ajute va multumesc. Link to comment
dan cod Posted December 6, 2012 Share Posted December 6, 2012 Daca TVul e cu tub de 21-22 e mult 146V si s-ar putea ca de aceea sa nu porneasca TVul. Link to comment
TIMIS STEFAN Posted December 6, 2012 Author Share Posted December 6, 2012 Daca TVul e cu tub de 21-22 e mult 146V si s-ar putea ca de aceea sa nu porneasca TVul.Multumesc pt sugestie da cu sursa artificiala tensiunea scade la normal tranzistorul linii transformatorul linii sint bune am schimbat si ci NN5198k tensiuni bune pe iel tot nu poneste merci. Link to comment
Marian C Posted December 6, 2012 Share Posted December 6, 2012 schimba c527 si vezi ce face Link to comment
TIMIS STEFAN Posted December 7, 2012 Author Share Posted December 7, 2012 schimba c527 si vezi ce faceAm schimbat C527 cu unu nou si tot nu porneste Multumesc. Link to comment
