vasile1312 Posted November 21, 2012 Share Posted November 21, 2012 buna ziua sunt nou pe sait am un receptor de satelit digi-tv cu urmatorul defect cand imaginea are alb in proportie de peste 75% se desincronizeaza pe baleajul de verticala. stie cineva ceva! :cry: Link to comment
raileanu florin Posted November 21, 2012 Share Posted November 21, 2012 pai tv-ul lati verificat?? Link to comment
dan cod Posted November 21, 2012 Share Posted November 21, 2012 Foarte posibil ca defect e TVul cum spune Florin.Da-i semnal de la alt aparat sa vezi tot asa face? Link to comment
filypvas Posted November 21, 2012 Share Posted November 21, 2012 Ca sa ti se raspunda corect posteaza corect cu lux de amanunte ... 1- Marca modelul .. 2-are softul nou sau cel vechi 3- ai verificat pe alt televizor 4- ce cablu face conexiunea semnal intre receptor si televizor ... deocamdata atat ...... Link to comment
vasile1312 Posted November 21, 2012 Author Share Posted November 21, 2012 receptorul este hyunday hss1170, tv-ul este perfect functional problema apare indiferent pe ce cale vizualizez semnalul de la receptor, euroscart-av-rf(mufa antena). Link to comment
filypvas Posted November 21, 2012 Share Posted November 21, 2012 hyunday hss1170 meniul simplu si asemanator cu al receiverului HSS-1160, pt satelitdai o revenire setari fabrica .....Atentie nu ii da actualizare sort deoarece noul soft iti blocheaza receptorul pa gigi Link to comment
vasile1312 Posted November 21, 2012 Author Share Posted November 21, 2012 nu merge tot asa face din pacate Link to comment
filypvas Posted November 21, 2012 Share Posted November 21, 2012 Daca le ai cu electronica da capacul jos ai 5 suruburi si verifica blocul alimentare, ceva cond unflati spune-mi ce cod are blocul alimentare are o serie pe el posibil model HD-800 ..... Link to comment
vasile1312 Posted November 22, 2012 Author Share Posted November 22, 2012 bine am sa verific sursa Link to comment
