aluneanu Posted November 16, 2012 Share Posted November 16, 2012 si mai am aceasta nelamurire ,ce final linii foloseste acest televizor. Este in capsula mica de plastic ,eu am gasit montat BU 808 in capsula mini .Dar nu are ce cauta acolo de vreme ce are transformator driver .L-am gasit avariat pe acesta si am montat 2SD 1555 . Deocamdata se comporta bine ! Link to comment
dan-a2 Posted November 16, 2012 Share Posted November 16, 2012 Cred ca e ok 1555 . schema de croma n2 nu se gaseste , il tii la proba si daca lucreaza normal in regim de temperatura : totul e o.k. !! Link to comment
dan cod Posted November 16, 2012 Share Posted November 16, 2012 Treaba e simpla.Daca nu are traf driver trebuie BU808,C5388.Daca are traf driver atunci eu as pune D2499,1803DHI deci ceva cu dioda si rezistenta. Link to comment
