valio_32 Posted October 18, 2012 Share Posted October 18, 2012 Tv nu se lumineaza,invertoare(P2803NVG,BIT3193G-SMD-uri toate)arse.In rest functioneaza normal.As avea nevoie de schema modulului "sursa-invertori",pentru a intelege functionarea.Sunt acolo si o multime de tranzistori si rezistente smd.Poate are cineva si vreo sugestie...Cu stima. Link to comment Share on other sites More sharing options...
sylver212003 Posted October 18, 2012 Share Posted October 18, 2012 schimba tranzistorii arsi si integratul si o sa-ti mearga 100 la 100 Link to comment Share on other sites More sharing options...
dan cod Posted October 18, 2012 Share Posted October 18, 2012 Ce scrie pe modulul ala?sa cautam schema.da toate datele. Link to comment Share on other sites More sharing options...
leoncris Posted October 19, 2012 Share Posted October 19, 2012 Myria MY20735 Pai nu este sasiu 17mb24-1 ? Link to comment Share on other sites More sharing options...
valio_32 Posted October 19, 2012 Author Share Posted October 19, 2012 Intr-adevar,este sasiu17MB24-01,iar modulul defect esteLIEN CHANG AIVP-0026. Link to comment Share on other sites More sharing options...
valio_32 Posted October 19, 2012 Author Share Posted October 19, 2012 Tot cautand,am gasit si schema,incarcata pe forum de Cristronic.Multumesc pentru sugestii,de asemenea lui Cristronic pentru fapta buna. Link to comment Share on other sites More sharing options...
adrianvmx Posted February 25, 2013 Share Posted February 25, 2013 Aceeasi placa am intalnit o de mai multe ori si am gasit doar un tranzistor ars dar acum am dat de belea .am schimbat condensatorul de 220uf am schimbat tranzistorul a pornit pentru o secunda si s a defectat cu tot cu celalat tranzistor cu care are grila in paralel.Epuizand stocul am pus de proba Si4532 in locul celor arse si desi este la 3 amperi functioneaza fara probleme dar se incalzesc in timp.Intre timp mi au sosit piesele original P2803nvg care s au ars instant am pus AO5606 , FDS8958a toate s au defectat instant am montat din nou Si4532 si surpriza merge . Link to comment Share on other sites More sharing options...
Archived
