lebensborn62 Posted October 16, 2012 Share Posted October 16, 2012 Buna dimineata , Ma poate ajuta vreun coleg cu un manual de service la tv-ul asta ? Eu am gasit o schema cu "H" in coada , care are jungla MC44006 , asta cu "G" avand MC44001 ; imi este de folos si asa , dar ma intereseaza si cum se intra in service mode .Multumesc Quote Link to comment Share on other sites More sharing options...
leoncris Posted October 16, 2012 Share Posted October 16, 2012 Ce sasiu ... este ?De regula la sandramalele astea se pune pinul de service la masa. Quote Link to comment Share on other sites More sharing options...
lebensborn62 Posted October 16, 2012 Author Share Posted October 16, 2012 nu stiu sasiul , pe placa de baza scrie DUNKT 7090 BM Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted October 16, 2012 Share Posted October 16, 2012 Aveti manualul service aici: http://elektrotanya.com/sharp_dv5150h_c ... nload.html Quote Link to comment Share on other sites More sharing options...
leoncris Posted October 16, 2012 Share Posted October 16, 2012 S3B Chassis DV3750H, DV3751H, DV5131H and DV5150H 1. Connect a test pattern to the antenna terminal 2. Tune to this signal 3. Connect a jumper wire between terminals 2 and 6 of the service slot on the video PWB 4. Press the MODE button on the remote control 5. 'SERV' will appear on the screen 6. Remove the jumper wire Use the channel up and down buttons to move between the options Use the volume control buttons to change the data Use the standby button on the remote control to store the data Turn the set off at the mains to exit the service mode. Quote Link to comment Share on other sites More sharing options...
lebensborn62 Posted October 16, 2012 Author Share Posted October 16, 2012 multumesc foarte mult , o zi plina ! Quote Link to comment Share on other sites More sharing options...
Join the conversation
