aly4quad Posted October 13, 2012 Share Posted October 13, 2012 Alimentez tv-ul, problema consta in aparitia unui arc electric intre fisa de inalta si miezul de ferita, mai precis intre acel varnis pe conductorul FIT si miezul de ferita. Ce este de facut? Oare traful trebuie schimbat? Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 13, 2012 Share Posted October 13, 2012 Este cumva sasiu TV2KR?daca da la asta este rezolvare. Quote Link to comment Share on other sites More sharing options...
aly4quad Posted October 13, 2012 Author Share Posted October 13, 2012 sasiul este: CP-330 Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 13, 2012 Share Posted October 13, 2012 Atunci trebuie schimbat traful.Defectarea este din cauza uscarii condului booster de 22uF/160V din pin 4 traf linii. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 13, 2012 Share Posted October 13, 2012 Buna seara ! Daca ne spuneti si scrile de pe trafo tv-ului,va putem oferi ce traf merge montat in locul lui,pentu ca daca ne luam dupa sasiu CP-330,atunci merg mai multe traf-uri . Asteptam serile de pe trafo dvs !!! Quote Link to comment Share on other sites More sharing options...
aly4quad Posted October 13, 2012 Author Share Posted October 13, 2012 pe traf nu se mai intelege nimic decat Daewo 21-2A... stantat pe pklastic, pe eticheta de hartie, nimic nu se mai vede. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted October 13, 2012 Share Posted October 13, 2012 viewtopic.php?f=17&t=79308 Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 13, 2012 Share Posted October 13, 2012 Buna seara ! Am revenit cu schemele traf-urilor date de domnul dan-a2 mai sus,pentru ca asa este mai usor pentru dvs,ca sa vedeti care din ele este cel potrivit la tv-ul dvs . Succes !!! Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 13, 2012 Share Posted October 13, 2012 Nu am acces la figurile trafurilor acum dar la figura a doua eu am mari indoieli.Eu nu am intalnit CP330 la care pinul 4 sa fie U1.Si cunisc sasiele astea de numa eu le-am facut garantii cand au aparut. Quote Link to comment Share on other sites More sharing options...
aly4quad Posted October 13, 2012 Author Share Posted October 13, 2012 Pe placa, in dreptul pinilor, am urmatoarele inscrisuri: 1-H.P. 2-B+ 3-AFC 4-BOOSTER 5-16,5V 6-26,5V 7-ABL 8-GND 9-VIDEO 10-HEATER Aceasta-i schema pentru CP-330: http://tinypic.com/r/25a518j/6 Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted October 14, 2012 Share Posted October 14, 2012 Dupa cele notate pe placa de baza primul traf care corespunde este HR7644. Pentru acest sasiu corespund si alte variante de traf: HR7493, HR7797, HR7930, HR7770 si HR7916. Toate sunt compatibile unul cu altul doar ca pinii 2 si 4 sunt folositi fie ca BOOSTER fie ca +B. Eu am folosit toate variantele, diferenta dintre ele fiind doar de cativa volti (pentru variantele de tub folosite). De asemenea am folosit, cand nu am avut nici una dintre variante, HR7880 (am deconectat traseul care vine in pinul 3 si l-am conectat la pinul 9). Totusi se mai pot folosi si alte variante de traf in cazul cand nici una din variantele de mai sus nu mai este disponibila........ Quote Link to comment Share on other sites More sharing options...
aly4quad Posted October 14, 2012 Author Share Posted October 14, 2012 Analizand configuratia lui HR7797 (trimisa de Florin Iordache), si facand comparatie cu schema sasiului CP-330, acesta cade din lista de traf echivalent pentru ca secundarul pinilor 8 si 10 difera. Oare gresesc? Deci, am pornit in cautarea unui traf din lista trimisa de Toni Marginean si dupa ce gasesc ceva, va voi comunica. VA MULTUMESC TUTUROR PENTRU SPRIJINUL ACORDAT! Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted October 14, 2012 Share Posted October 14, 2012 La amandoua transformatoarele postate de Florin pinul 8 este la masa iar la 10 este tensiunea de filament. Quote Link to comment Share on other sites More sharing options...
iod2 Posted October 14, 2012 Share Posted October 14, 2012 eu am gasit la magazin hr 7797 la 35lei si merge fara probleme pe CP-330, dar cum a zis nea dan. condul din piciorul 4 trebuie schimbat. Quote Link to comment Share on other sites More sharing options...
Join the conversation
