Guest georgila Posted October 12, 2012 Share Posted October 12, 2012 va rog daca stie cineva ce bloc optic foloseste? sau unde l-as putea gasi. merci. (sigur e blocul optic ca am marit deja de 2 ori curentul) Quote Link to comment Share on other sites More sharing options...
misuraelectronic Posted October 12, 2012 Share Posted October 12, 2012 acest aparat este echipat cu grupul optic rcd1.3 ...! Quote Link to comment Share on other sites More sharing options...
Guest georgila Posted October 13, 2012 Share Posted October 13, 2012 acest aparat este echipat cu grupul optic rcd1.3 ...!merci. asta gasisem si eu, dar toate foto de la rcd 1.3 care le-am vazut pe net nu seamana cu ce am eu. cred ca undeva e o greseala. merci inca odata Quote Link to comment Share on other sites More sharing options...
Guest georgila Posted October 13, 2012 Share Posted October 13, 2012 am gasit ce cautam. desi e un philips foloseste SFP100S-CD93 Sanyo.(13 pini) poate mai are nevoie cineva Quote Link to comment Share on other sites More sharing options...
misuraelectronic Posted October 13, 2012 Share Posted October 13, 2012 adevarul este ca acest aparat are modelul corect si complet az8051 / xy , iar acel xy se afla in intervalul 00 ...19 , in total fiind 9 variante diferite...! o parte dintre cele 9 variante sint echipate din fabrica , conform manualului service original de la philips , cu grupul optic rcd1.3 ...! de aici a aparut confuzia , dvs nespecificindu-ne clar ce terminatie are aparatul dvs ...! Quote Link to comment Share on other sites More sharing options...
Join the conversation
