mircea65 Posted October 12, 2012 Share Posted October 12, 2012 Buna dimineata.la acest tv-defect cadre am inlocuit C-urile 610, 641,603,636,644,631,616, R6311,5Kohmi, verificat D602 si apoi am montat TDA8174AW pe care l-am cumparat dintr-o sursa sigura. Am pornit tv-ul imaginea este buna fara probleme de liniaritate, insa pe pinii 7 si 8 tens. sunt cam cu 3volti mai mari fata de normal, adica 8,4v respectiv 9,4v, iar integratul se cam incinge-in rest pe ceilalti pini tens. sunt apropiate de normal. U1-113V, iar tens. de alimentare cadre este 27,3v in loc de 26v. Cam ce ar mai fi de inlocuit in situatia descrisa?multumesccu stima!P.S. La o depanare anterioara cu acelasi defect a avut montat un radiator suplimentar, iar eu am gasit integratul explodat. Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 12, 2012 Share Posted October 12, 2012 Cate grade are radiatorul?in general merg calde bine in aparatele astea.banuiesc ca condul boostrap s-a schimbat. Quote Link to comment Share on other sites More sharing options...
mircea65 Posted October 12, 2012 Author Share Posted October 12, 2012 Nu am masurat temp. dar dupa o jumatate de ora este fierbinte, banuiesc 55-60 grade nu pot tine mana pe el decat cateva secunde. La care cond va referiti C6... sau in ce pin al integratului este? Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 12, 2012 Share Posted October 12, 2012 C610 este boostrapul.Ala este primul care trebuie inlocuit in defect de BV. Quote Link to comment Share on other sites More sharing options...
mircea65 Posted October 12, 2012 Author Share Posted October 12, 2012 primul a fost inlocuit.... Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 12, 2012 Share Posted October 12, 2012 Ar mai fi de verifica filtrul antioscilatie C611 R623. Quote Link to comment Share on other sites More sharing options...
mircea65 Posted October 12, 2012 Author Share Posted October 12, 2012 O sa schimb si filtrul si va tin la curent.multumesc.cu stima! Quote Link to comment Share on other sites More sharing options...
mircea65 Posted October 15, 2012 Author Share Posted October 15, 2012 Buna dimineata.Am schimbat filtrul-nicio schimbare, am pus radiatorul suplimentar si temperatura este OK-cred ca o sa-l las asa.multumesccu stima! Quote Link to comment Share on other sites More sharing options...
blazeu Posted October 31, 2012 Share Posted October 31, 2012 Daca i-ati "dat drumu" poate foloseste pe viitor si/sau altor colegi:La un tv depanat in urma cu cativa ani, integratul de putere pentru baleiajul vertical era alimentat cu 25 de volti, valoarea maxima a Vcc fiind de 26 de volti!!!Un condensator in baza tranzistorului de putere din sursa fiind "obosit", tensiunile o luasera "in sus" si astfel se depasise valoarea aceea de 26 de volti. Mi-a sunat cumva cunoscut faptul ca aveti tensiunile marite la alimentare. Poate ar fi bine de sapat si prin sursa si adus alimentarile la valorile corecte.Succesuri! Quote Link to comment Share on other sites More sharing options...
mercenarx Posted October 31, 2012 Share Posted October 31, 2012 ....Nu am masurat temp. dar dupa o jumatate de ora este fierbinte, banuiesc 55-60 grade nu pot tine mana pe el decat cateva secunde....asta e temperatura de lucru normala....daca are si radiator suplimentar , cu atat mai bine Quote Link to comment Share on other sites More sharing options...
alex_serv57 Posted December 17, 2013 Share Posted December 17, 2013 Fara a deschide alt topic cer ajutorul vostru . primesc un tv zander ft2101 . cu problema de cadre (dunga alba pe jumatatea ecranului ) . Schimb resistenta de 1 ohm /1w din sursa integratului de cadre .schimb toti electrolitici de pe langa integrat .masor rezistoarele ok tensiunea de alimentare = 26 volt Integratul tda 1874A il schimb cu tda 1874AW (cu modificarile necesare pentru prinderea acestuia pe radiator) .Rezultat = imaginea se deschide doar jumatate din cat ar trebui .Am intrat in meniul service insa nu am reusit mare lucru .Din ce stiu tda 1874A si tda 1874AW nu au alte caracteristici personale exceptand dimensiunea si modalitatea de prindere pe radiator .Ceva idei ? Quote Link to comment Share on other sites More sharing options...
elmar Posted December 17, 2013 Share Posted December 17, 2013 Din ce stiu tda 1874A si tda 1874AW nu au alte caracteristici personale exceptand dimensiunea si modalitatea de prindere pe radiator .cred ca e vorba de TDA8174....cat e tensiunea de alimentare cadre? C326,C323 si R320 le-ati verificat? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted December 17, 2013 Share Posted December 17, 2013 integratele 8174a si aw sunt identice mai putin capsula,cred ca cel montat e defect Quote Link to comment Share on other sites More sharing options...
flomar60 Posted December 17, 2013 Share Posted December 17, 2013 Daca imaginea este stransa simetric ,sus si jos atunci este o problema de adaptare a amplificarii globale a acestui CI fata de celalalt CI relativ la impedanta bobinei de deflexie cadre . Pt. asta verificati componentele de la pinul 4 al CI in special rez. 603 ( micsorati valoarea ) Faceti asta doar daca imaginea este stansa simetric , daca nu , cele de mai sus nu sunt valabile... Quote Link to comment Share on other sites More sharing options...
elmar Posted December 18, 2013 Share Posted December 18, 2013 Fara a deschide alt topic cer ajutorul vostru . primesc un tv zander ft2101 . cu problema de cadre (dunga alba pe jumatatea ecranului )dl.flomar60 ati atasat o parte din schema sasiu-lui 11ak30? ...dar dl.alex_serv57 are alt sasiu! ...cred ca e vorba de zander ft2105 ... Quote Link to comment Share on other sites More sharing options...
Join the conversation
