Guest florin18 Posted October 9, 2012 Share Posted October 9, 2012 salut!am o problema cu tv-ul lg!l-am dus la reparat pt ca nu mai pornea din standbay.dupa ce la reparat,imaginea la tv se vede mai alungita atat pe orizontala cat si pe verticala,iar culorile nu mai sunt ca inainte.mi sa spus ca nu au gasit piesa care trebuie si au pus altceva....de la ce poate fi problema asta?multumesc! Quote Link to comment Share on other sites More sharing options...
nostrom Posted October 10, 2012 Share Posted October 10, 2012 Mergeti la alt depanator. Quote Link to comment Share on other sites More sharing options...
dan cod Posted October 10, 2012 Share Posted October 10, 2012 Sfatul colegului este bun.Probabil a crescut tensiunile din sursa si asta poate deteriora si altceva.In ziua de azi e greu sa spui nu am gasit piesa am pus altceva.Asta da nu cumva a schimbat deflexia si atunci mai trebuie bibilit. Quote Link to comment Share on other sites More sharing options...
Guest florin18 Posted October 10, 2012 Share Posted October 10, 2012 cred ca a avut dreptate ,ca nu se gaseste piesa !?este vb de acest tranzistor:q401-0TRSA10004A-TT2170LS-YB11 ST TO-220FM 1500V 5A...am cautat online si nu am gasit nimic in romania.. stiti cu ce il pot inlocui??multumesc! Quote Link to comment Share on other sites More sharing options...
circiumaru Posted October 10, 2012 Share Posted October 10, 2012 Se poate inlocui cu TT2190LS. Quote Link to comment Share on other sites More sharing options...
Guest florin18 Posted October 10, 2012 Share Posted October 10, 2012 multumesc!...o sa caut maine prin oras pe lamine sa vad daca gasesc... Quote Link to comment Share on other sites More sharing options...
circiumaru Posted October 10, 2012 Share Posted October 10, 2012 Daca nu gasesti am eu la 8 lei buc. dar trebuie sa dai comanda de minim 20 lei. Quote Link to comment Share on other sites More sharing options...
Guest florin18 Posted October 10, 2012 Share Posted October 10, 2012 ai cumva si un condensator ca asta:MPP 1600V 0.0068UF polipropilena sau condensatori 15000 uF 63v sau tranzistori 2sa1216.... Quote Link to comment Share on other sites More sharing options...
circiumaru Posted October 11, 2012 Share Posted October 11, 2012 Am numai 10000uF/100v. Quote Link to comment Share on other sites More sharing options...
Join the conversation
