mercenarx Posted October 5, 2012 Share Posted October 5, 2012 salutare!poate cineva sa-mi spuna cum se intra in ms la chinezaria asta?sasiu Tousda TH11135A.PCB (procesorul din titlu)thx anticipat!meniu 6483? Quote Link to comment Share on other sites More sharing options...
popa ionut Posted October 5, 2012 Share Posted October 5, 2012 La telecomanda este un buton ascuns in partea dreapta jos sub eticheta apasa pe el si intra in meniu service daca nu merge incearca cu meniu 1,4,0,4 ori meniu 6,4,8,0. te-a pricopsit dumnezeu cu pocnitoarea aia Quote Link to comment Share on other sites More sharing options...
mercenarx Posted October 6, 2012 Author Share Posted October 6, 2012 a mers cu meniu 6483 Quote Link to comment Share on other sites More sharing options...
Join the conversation
