Guest Bogdanelhh Posted October 3, 2012 Share Posted October 3, 2012 Salut, am un samsung LE37A656A1F si are imaginea gri + niste liniute verticale care apar de la subtitrare in jos, sau daca sunt pe un post tv si apoi il schimb ramane sters numele postului anterior pe ecran, apoi in timp dispare, negrul este un gri f deschis. Sunetul este OK, imaginea are aceleasi probleme indiferent de sursa, HDMI, USB, TV tunner... pe placa de alimentare incercuit cu rosu este un condensator care merge incins... nu stiu de ce... daca e nevoie de informatii mai multe sunt pregatit sa le furnizez. Mai multe detalii despre model dupa eticheta de pe spate: Model : LE37A656A1F Model Code : LE37A656A1FXXH Type No. : LE37A656 Poze la o rezolutie mai mare: https://dl.dropbox.com/u/60894638/smsung/alimentare.JPG https://dl.dropbox.com/u/60894638/smsung/ansamblu.JPG https://dl.dropbox.com/u/60894638/smsun ... debaza.JPG https://dl.dropbox.com/u/60894638/smsung/unk.JPG https://dl.dropbox.com/u/60894638/smsung/label.JPG https://dl.dropbox.com/u/60894638/smsung/imagine.JPG https://dl.dropbox.com/u/60894638/smsung/imagine1.JPG https://dl.dropbox.com/u/60894638/smsung/imagine2.JPG https://dl.dropbox.com/u/60894638/smsung/imagine3.JPG https://dl.dropbox.com/u/60894638/smsung/imagine4.JPG https://dl.dropbox.com/u/60894638/smsung/imagine5.JPG Link to comment
paull00 Posted October 4, 2012 Share Posted October 4, 2012 Verifica(misca de ele in timp ce functioneaza) cele 2 cabluri lvds care leaga digitala de display de modulul adaptor lvds. Link to comment
Guest Bogdanelhh Posted October 4, 2012 Share Posted October 4, 2012 am miscat, nu e intampla nimic, liniile verticale sunt afisate aleator de diferite culori. Poza cu meniu https://dl.dropbox.com/u/60894638/smsung/meniuon.JPG Poza dupa ce a fost afisat meniul https://dl.dropbox.com/u/60894638/smsung/meniuoff.JPG Video cu imagine oaWMRGlZ_kY Link to comment
horhogea Posted October 4, 2012 Share Posted October 4, 2012 condensatorul din sursa care se incinge la-i schimbat? Link to comment
Guest Bogdanelhh Posted October 4, 2012 Share Posted October 4, 2012 nu inca, maine ma duc si cumpar mai multe condensatoare sa le schimb pe astea de pe partea cu placa de baza, pe partea cu backlight e ok. am observat inca un condensator care are cauciucul impins spre placa.. n-a vrut sa se umfle in sus intre timp am gasit si schema modulului. https://dl.dropbox.com/u/60894638/smsun ... 00213a.pdf Condensatorii despre care vorbesc sunt notati in schema cu CM856 sau CM858 cel de 25V de pe pagina 2 pe linia de 12V pe partea COLD, si CB804 care este pe pagina 1 legat in serie cu dioda intre GND si FB la ICB801S Am mai gasit si schema asta: https://dl.dropbox.com/u/60894638/smsun ... XC_SCH.pdf Numai ca modelul pe care il detin este FXXH mari diferente intre ele nu cred ca sunt. Link to comment
Guest Bogdanelhh Posted October 5, 2012 Share Posted October 5, 2012 Am schimbat toate condensatoarele de pe sursa de alimentare, nimic modificat... aceleasi probleme... Link to comment
Guest Bogdanelhh Posted October 6, 2012 Share Posted October 6, 2012 am conectat pc-ul la el si am obtinut imaginea asta : https://dl.dropbox.com/u/60894638/smsun ... screen.jpg a mai avut cineva problema asta? Link to comment
paull00 Posted October 6, 2012 Share Posted October 6, 2012 Da jos capacul de tabla de la modulul t-con(digitala de display) si vezi ce se incinge pe acolo. Link to comment
Guest Bogdanelhh Posted October 6, 2012 Share Posted October 6, 2012 Multumesc! Am gasit in controllerul de LCD acest inamic prajit destul de rau, nu am reusit inca sa gasesc numele lui complet, sau inlocuitori pt el... si sa vad si ce pini sunt aia si sper sa gasesc si de ce s-a prajit asa, daca stie cineva de ce... https://dl.dropbox.com/u/60894638/smsung/toasted.jpg Link to comment
Guest Bogdanelhh Posted October 24, 2012 Share Posted October 24, 2012 am schimbat as15-f merge perfect pana in prezent imaginea... problema care a aparut intre timp este cu tunnerul... fara antena face puricii, iar cand conectez antena, se vede in purici antena1, fara culoare si se deplaseaza de la stanga la dreapta... A4Asd-HJahI&hd=1 daca a mai intalnit cineva problema asta si e dispus sa ma ajute... Tunnerul este ALPS, iar cand dau pe DTV imi spune ca nu este disponibil. cand ii dau sa scaneze dupa posturi ramane imaginea aceea cu a1 si nu se schimba nimic desi pe meniu apare cum ca ar schimba frecventele.edit: celelalte surse de imagine merg perfect, sunet OK Link to comment
Guest Bogdanelhh Posted October 24, 2012 Share Posted October 24, 2012 am uitat sa mentionez ca si tensiunile de intrare in tuner sunt ok, chiar si cea de 33v Link to comment
paull00 Posted October 24, 2012 Share Posted October 24, 2012 Vezi in service mode ce selector este. Link to comment
Guest Bogdanelhh Posted October 24, 2012 Share Posted October 24, 2012 este pus pe auto Link to comment
ion_vasile Posted October 25, 2012 Share Posted October 25, 2012 Auto --este in meniul de cautare,ori Paul ti-a spus sa verifici meniul service. Link to comment
Guest Bogdanelhh Posted October 25, 2012 Share Posted October 25, 2012 auto este pus in meniul de service. Link to comment
