Guest d3luxsoft Posted October 1, 2012 Share Posted October 1, 2012 Sunet-ul se aude dar nu are imagine, in ultimul timp mergea, m-ai disparea dar era in regula.Acum dak il pornesc fara antena porneste tub-ul merge putin si se opreste dar cu antena bagata nu mai pleaca tub-ul dr sunet-ul se audeAm refacut lipit-uri la traf, si la placa video, ce parere aveti de defecte la acest tv Quote Link to comment Share on other sites More sharing options...
cristi71 Posted October 1, 2012 Share Posted October 1, 2012 trebuie sa faceti ceva masuratori..liniile pleaca? se aprinde filamentul tubului? Quote Link to comment Share on other sites More sharing options...
Guest d3luxsoft Posted October 2, 2012 Share Posted October 2, 2012 cand are imagine da, dar dupa ce ramane fara e stins Quote Link to comment Share on other sites More sharing options...
cristi71 Posted October 2, 2012 Share Posted October 2, 2012 aprinderea filamentului e conditionata de functionarea etajului final linii (alimentare din trafo linii) deci trebuie verificat daca liniile mai functioneaza in acel moment. refaceti lipiturile la pinii trafo linii posibil sa fie acolo lipituri reci. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted October 2, 2012 Share Posted October 2, 2012 Sa fie sasiu 11ak 30 ?? > viewtopic.php?t=76280&f=16Eu personal nu am gasit IVORY cu sasiu de ak30 > scrie cumva pe eticheta din spate 11 ak 30 ?? Quote Link to comment Share on other sites More sharing options...
Guest d3luxsoft Posted October 2, 2012 Share Posted October 2, 2012 Sa fie sasiu 11ak 30 ?? > viewtopic.php?t=76280&f=16Eu personal nu am gasit IVORY cu sasiu de ak30 > scrie cumva pe eticheta din spate 11 ak 30 ??Vizual pare acelasi sasiu cu 11ak 30, e posibil sa fie. Nu m-am uitat pe eticheta. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted October 2, 2012 Share Posted October 2, 2012 Inlocuiti C619 ,daca e acest sasiu !! Quote Link to comment Share on other sites More sharing options...
Guest d3luxsoft Posted October 2, 2012 Share Posted October 2, 2012 Ce tensiuni de alimentare ar trebui sa am la alimentarea traf-ului Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted October 2, 2012 Share Posted October 2, 2012 O singura tensiune: +B pe care trebuie sa o regasiti in colector la finalul linii prin infasurarea trafo. Quote Link to comment Share on other sites More sharing options...
Join the conversation
