nationalistu Posted September 30, 2012 Share Posted September 30, 2012 Tv-ul LG RZ-21FB35MX,are urmatorul defect,nu are imagine,in schimb are sunet,pe canalele memorate.Am verificat urmatoarele tensiuni:BV +/- 14v ok, B+ 115v ok, am gasit alimentarea final video 186v,si alimentare filament tk pare insuficienta,nu am aparat true rms,si din experienta mea pe un tv bun am undeva 5,3v,la acest tv am 4,2v pe filament.Modificand din potentiometrul G2 nu apare nimic pe ecran.Orice sugestie e binevenita.Multumesc anticipat. http://imageshack.us/a/img217/1319/dsci1281.jpg http://imageshack.us/a/img202/291/dsci1282v.jpg http://imageshack.us/a/img826/2746/dsci1283e.jpg Link to comment
popa ionut Posted September 30, 2012 Share Posted September 30, 2012 Daca nu iti apare chiar nimic pe ecran posibil sa ai trafo defect pe infasurarea de inalta.. ,ori lipsa filament ...filamentul se inroseste??ma mir ca nu iti apare nimic cand maresti g2...linii de intoarcere...ceva pe acolo....inalta are trafo??scoate ceva?? Link to comment
dan-a2 Posted September 30, 2012 Share Posted September 30, 2012 Nu ati spus nimic despre tensiunea pe G2 !! Link to comment
nationalistu Posted September 30, 2012 Author Share Posted September 30, 2012 Sigur ca se inroseste dar nu cum ar trebui. Link to comment
nationalistu Posted September 30, 2012 Author Share Posted September 30, 2012 Nu ati spus nimic despre tensiunea pe G2 !!Am masurat cu firul G2 scos din soclu tk tensiunea variaza intre 89...450v prin actionarea potentiometrului G2 dupa traf, surpriza la montarea in soclu a firului tensiune G2 tensiunea scade undeva la 0,4V. Link to comment
nationalistu Posted September 30, 2012 Author Share Posted September 30, 2012 Gata am verificat si inalta...exista dar lipseste cu desavarsire,traf partial busit. Link to comment
dan cod Posted September 30, 2012 Share Posted September 30, 2012 Tare mii frica ca ai dat verdict gresit.Daca UG2 scade in sarcina poti avea soclul tk defect,eclatorul defect sau scurt in tk intre G1 si G2 frecvent la LGuri.Asa ca mai verifica odata asta.Daca traful era defect in secundar pe FIT sigur consuma mult. Link to comment
cristi71 Posted September 30, 2012 Share Posted September 30, 2012 Gata am verificat si inalta...exista dar lipseste cu desavarsire,traf partial busit.chiar nu am inteles nimic de aici...sigur cadrele functioneaza? se aude frecventa de cadre daca ascultati linga deflexie?(sau verificat cu un osciloscop) Link to comment
nationalistu Posted October 1, 2012 Author Share Posted October 1, 2012 Cadrele functioneaza,se aude zgomotul specific in deflexie,am scos fisa fit de la tub si am verificat cu o surubelnita la cativa cm nu am descarcarea specifica,e foarte mica .Totusi am sa probez sasiul pe alt tub. Link to comment
bobo Posted October 1, 2012 Share Posted October 1, 2012 de ce nu ascultati de sfaturile adevaratilor depanatori(ma refer la dan cod) care vorbesc din experienta.daca cu firul de screen scos aveti intre 0-400v iar cu el lipit pe placa tensiunea ug2(screen) scade la ov atunci tub cu scurt intre g1 si g2. se poate remedia prin descarcarea unui cond de 47-100micro/400v intre pinii g1 si g2 direct pe pinii tubului cu soclul scos.se pare ca defectuleste comun tuburilor slim,ultraslim fabricate in ultimii ani.personal m-am intalnit cu un defect similar de curand.rezolvarea jos:viewtopic.php?f=17&t=94675&start=15 Link to comment
nationalistu Posted October 1, 2012 Author Share Posted October 1, 2012 Sigur apreciez parerea unui depanator profesionist,dar pentru a-mi satisface curiozitatea am sa probez sasiul pe alt tub. Link to comment
nationalistu Posted October 4, 2012 Author Share Posted October 4, 2012 Am testat placa...functioneaza impecabil,urmeaza sa vad daca pot elimina scurtul din tub. Link to comment
nationalistu Posted October 5, 2012 Author Share Posted October 5, 2012 Eliminat si scurtul din tub cu o rezistenta ca sarcina {fier de calcat} Link to comment
legionaru Posted October 5, 2012 Share Posted October 5, 2012 am avut azi un televizor identic, acelasi sasiu, acelasi model, acelasi defect.... rezolvarea: descarcarea condensatorului prin metoda descrisa mai sus! Link to comment
nationalistu Posted October 5, 2012 Author Share Posted October 5, 2012 Metoda cu rezistenta de sarcina in speta fier de calcat...e mai rustica. Link to comment
