Guest morkoveata Posted September 17, 2012 Share Posted September 17, 2012 am un philips 21pt5402/58 si vede ca in 16:9 dar nu este cand dau 16:9 se face si mai mic.aveti vre-o idee de la ce ar putea fi? Link to comment
modoran Posted September 17, 2012 Share Posted September 17, 2012 Ai dimensiune redusa pe verticala, schimba toti condensatorii electrolitici din acest bloc, in special cel de iesire. Link to comment
Guest morkoveata Posted September 17, 2012 Share Posted September 17, 2012 Ai dimensiune redusa pe verticala, schimba toti condensatorii electrolitici din acest bloc, in special cel de iesire.te referi la cei de pe langa tda1771? Link to comment
Guest morkoveata Posted September 18, 2012 Share Posted September 18, 2012 schimbati,problema persista Link to comment
dan cod Posted September 18, 2012 Share Posted September 18, 2012 Poate alterat dumpul si trebuie marita din service.Asta daca restul tot este ok langa Blocul de BV. Link to comment
Guest morkoveata Posted September 18, 2012 Share Posted September 18, 2012 tensiunile par ok,adica sunt ca in schema ce am masurat pana acum(cei 24v)problema sa intamplat cand sa miscat din priza.si cum intru in service Link to comment
bobo Posted September 18, 2012 Share Posted September 18, 2012 viewtopic.php?f=17&t=62743modificati la geometry parametrul vs 4;3(vertical size) dar mai bine notati undeva valoarea initiala pt a putea reveni in caz ca nu se rezolva din service mode.aveti grija ce si cum modificati ca sa nu va uitati la radio.mai multe informatii in revista depanatorul nr 28 pag 64.ps: o dresa de mail sa va trimit revista. Link to comment
Guest morkoveata Posted September 18, 2012 Share Posted September 18, 2012 http://www.elforum.info/viewtopic.php?f=17&t=62743 modificati la geometry parametrul vs 4;3(vertical size) dar mai bine notati undeva valoarea initiala pt a putea reveni in caz ca nu se rezolva din service mode. aveti grija ce si cum modificati ca sa nu va uitati la radio. mai multe informatii in revista depanatorul nr 28 pag 64. ps: o dresa de mail sa va trimit revista. [email protected] Link to comment
bobo Posted September 18, 2012 Share Posted September 18, 2012 din pacate nu merge sa va atasez revistape mail,este prea mare.v-am spus ce sa modificati. Link to comment
Guest morkoveata Posted September 18, 2012 Share Posted September 18, 2012 din pacate nu merge sa va atasez revistape mail,este prea mare.v-am spus ce sa modificati.nu o puteti compresa in arhiva rar cu mai multe volume?ms Link to comment
horhogea Posted September 18, 2012 Share Posted September 18, 2012 Meniu service:0-6-2-5-9-6-MENU Link to comment
Guest morkoveata Posted September 19, 2012 Share Posted September 19, 2012 Meniu service:0-6-2-5-9-6-MENUmersi inca nu am telecomanda(tv-ul e al cumnatului si zapacitul nu m-ia adus-o) Link to comment
dan cod Posted September 19, 2012 Share Posted September 19, 2012 In service se intra asa .TVul in stby 062596 OSD Link to comment
Guest morkoveata Posted September 19, 2012 Share Posted September 19, 2012 In service se intra asa .TVul in stby 062596 OSDok mersi.sa vina telecomanda si va spun ce am facut. Link to comment
bobo Posted September 19, 2012 Share Posted September 19, 2012 sasiul este TE3.2E si se intra in service mode cu 062596 MENU.o sa incerc iar sa va trimit revista si manualul de service unde scrie foarte clar ce si cum.asta ca tema de studiu pana primiti telecomanda. Link to comment
