emy_dx Posted September 15, 2012 Share Posted September 15, 2012 Salutare tuturor.Acest tv echipat cu sasiu GR2.2 AA mi-a scos peri albi.La comanda ''on'' tensunile fluctueaza,i-am scos finalul de linii montat bec pe colector apare tensiunea de 145v,pe schema am vazut ca trebuia 95v in sarcina.Il trec in st/by 53v cu sarcina.In ''on'' ledul palpaie continu iar la trecerea in st/by ramane aprins fara sa palpaie.I-am schimbat in sursa condul de 68uf am pus de 100uf si opto CNR50.Vre-o idee pentru acest sasiu.Multumesc Link to comment
leoncris Posted September 15, 2012 Share Posted September 15, 2012 Ia mai vezi odata schema , ca le cam incurci. http://www.eserviceinfo.com/downloadsm/ ... lips_.html Link to comment
emy_dx Posted September 15, 2012 Author Share Posted September 15, 2012 Ce anume am incurcat?Aceasi schema o am si eu. Sasiu GR2.2AA Link to comment
leoncris Posted September 15, 2012 Share Posted September 15, 2012 148V trebuie sa ai acolo .Celelalte tensiuni , cum sunt ? Link to comment
Toni Marginean Posted September 15, 2012 Share Posted September 15, 2012 De obicei la acest sasiu schimb vreo 5 condensatoare electrolitice (care se si vad curse sau miros urat). Abia apoi trec la masuratori. Link to comment
emy_dx Posted September 18, 2012 Author Share Posted September 18, 2012 Am schimbat toti electroliticii din primar si secundar,am schimbat si TDA8385,tensiunile secundare sunt corecte cu becul dar cu final linii pus imi fluctueaza toate tensiunile din secundar.Nu am gasit nici un scurt sau consumator pe secundar.Tensiunile din secundar sunt: 16V -16V 31V 10V 12V 147VLedul palpaie si fara sarcina artificiala cand il aduc in starea on.Un sfat va rog Link to comment
Toni Marginean Posted September 18, 2012 Share Posted September 18, 2012 Poate fi defect trafo linii. Link to comment
emy_dx Posted September 27, 2012 Author Share Posted September 27, 2012 Poate fi defect trafo linii.Adevarat.Am schimbat traful cu unul original si acum functioneaza perfect.Ma gandeam si la trafo dar nu eram sigur,cei drept ca nu am nici cu ce sa-l masor si nici nu aveam altul.Multumesc tuturor. Link to comment
