Guest costeatek Posted September 7, 2012 Share Posted September 7, 2012 daca stie cineva un defect la un tv lcd 32le2r la care era defecta sursa toti electroliticii si un irfu 7807 dupa ce am schimbat tot a functionat tv-ul ok dar cind l-am inchis surpriza merge corect 2 secunde dupa care jumatate din imagine se intoarce in oglinda .help me Quote Link to comment Share on other sites More sharing options...
tntgarbage Posted September 8, 2012 Share Posted September 8, 2012 cred ca am mai citit aici pe forum acest defect localizat in zona LVDS-ului, respectiv unul din cipuri,nu stiu exact ce display ai tu.ideal ar fi sa inlocuiesti LVDS-ul si sa vezi daca face la fel. Quote Link to comment Share on other sites More sharing options...
Join the conversation
