Traian M Posted September 6, 2012 Share Posted September 6, 2012 Acest tv nu functioneaza din telecomanda,in rest e ok, comenzile din panoul frontal functioneaza normal, telecomanda este buna(probata),am schimbat receptorul IR,mai ramane procesorul TDA9351ps/N2/3/0457 pe care il banuiesc. Daca aveti sugestii va rog sa ma ajutati. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 7, 2012 Share Posted September 7, 2012 Ai schimbat receptorul IR , da' tensiunile le masurasi ?E telecomanda ...originala ? Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 7, 2012 Share Posted September 7, 2012 Semnalul de la receptor ajunge pe pinul procesorului?Ce tensiune ai pe acest traseu? Quote Link to comment Share on other sites More sharing options...
naebv Posted September 7, 2012 Share Posted September 7, 2012 am schimbat receptorul IR,mai ramane procesorul TDA9351ps/N2/3/0457 pe care il banuiesc.Inainte de a banui procesorul, mai pot fi alte cauze cum ar fi de exemplu quartzul la...procesor. Quote Link to comment Share on other sites More sharing options...
Traian M Posted September 7, 2012 Author Share Posted September 7, 2012 telecomanda nu-i originala ,arata ca acea originala e made in china,am probato cu camera foto si la alte tipuri de tv (teletec,philips) executa unele comenzi. Tensiunile pe receptor IR :pe pinul de alimentare are 5.3v pe cel de semnal are tot5.3 ,iar cand actionez telecomanda tensiunea pe pinul 62 se duce la 4.5v. Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 7, 2012 Share Posted September 7, 2012 Primul lucru este ca 5,3V acolo nu-i ok deloc.Mai mult de 5,1V nu are de ec asa fie.Cu telecomanda de teletech ai incercat sa vezi ce face?Verificatul cu camera foto nu spune mare lucru din pacate. Quote Link to comment Share on other sites More sharing options...
Traian M Posted September 7, 2012 Author Share Posted September 7, 2012 cu telecomanda de teletech acelasi treaba, sa vad cei cu tensiunea de 5,3v Quote Link to comment Share on other sites More sharing options...
Traian M Posted September 7, 2012 Author Share Posted September 7, 2012 tensiunea de 5.3vine prin rezistenta R827 de 300ohmi din bara de 12v si se duce la memorie si la receptorul IR .ambele au diode stabilizatoare de 5.6v, in schimb pe schema dioda de pe alimentarea memoriei DZ901 este de 4v7 iar pe placa tv este montata de 5v6, am montat in locul ei o dioda de 5v1 si acum tensiunile pe IR sunt de 5.1v iar semnalul intre 4,2 si 5.0 cind este actionata telecomanda, in schimb tot nu functioneaza . Am schimbat si quartzul si tot la fel ,ramane sa mai caut o alta telecomanda Quote Link to comment Share on other sites More sharing options...
Traian M Posted September 7, 2012 Author Share Posted September 7, 2012 Am rezolvat problema, este de vina telecomanda am reusit sa-i dau de capat cu o telecomanda universala.Va multumesc. Quote Link to comment Share on other sites More sharing options...
Join the conversation
